SolaraGuy.com • View topic - Problem Running to lean, Fuel/O2 Ratio mix off
Postby nigglewires555 » Sat Sep 26, 2009 2:50 pm
I Just installed a supercharger and JP headers + Exhaust system. The Supercharger pulley is the stock one that came with it, so its nothing crazy.. The Problem I'm having is that the computer is not mixing the Fuel/o2 mix correctly and I had a guy at toyota hook it up to the computer, its reading 19% lean which he said it should be close to zero or under 5%. What should I do? Should i go with bigger fuel injectors? Will that help? What ones do I need? or Take the car to be dyno'd and see if they can tune the fuel/o2 ratio Without bigger fuel injectors. I want to try to keep the cost down on fixing the problem, running low on cash! If anyone could give me any suggestions, I would appreciate it. Thanks
nigglewires555
Postby Midias » Sat Sep 26, 2009 2:53 pm
Well the search function is free.
Otherwise you need an apexi neo or safc2 and fuel mod kit would help.
Postby trd4life » Sat Sep 26, 2009 3:08 pm
PM'd you
Postby GzNutz » Sat Sep 26, 2009 3:11 pm
Midias wrote:Well the search function is free.
^yeah, you really should have some type of aftermarket tuning device installed. The JP headers alone will throw the AFR off.
Postby nigglewires555 » Sat Sep 26, 2009 6:10 pm
Thanks everyone, I think i'm going to get the apexi neo to tune the air/fuel ratio after talking to a friend of mine, i guess he has one for a scion and works great. Hopefully that will work.
nigglewires555
Postby Eye8Pussies » Mon Sep 28, 2009 12:06 pm
are you running lean in closed loop or open loop?
Postby mazen222 » Mon Sep 28, 2009 2:40 pm
search function is sh!t as far as i have seen... admin should really invest on fixing it... the google plugin should be used instead
1999, 5 Speed V6
mazen222
Postby Midias » Mon Sep 28, 2009 2:47 pm
I never have a problem finding what I am searching for. You must be doing it wrong.
Return to Forced Induction
Users browsing this forum: No registered users and 249 guests
