SolaraGuy.com • View topic - *Update* Boosted to 6psi, Need Guidance
Postby SpeedySolara » Sat Sep 26, 2009 5:23 pm
Within the past week a lot of work and modifications have been in the works with my car. I'm currently boosted at 6 psi and will have the Supra injectors installed monday. Thereafter I will go for a good tune. In the meantime, I need some advice as to what my AFC/NEO fuel settings should be at. Please recommend some values as I dont want to run too rich and blow my motor on my way to the get the car tuned.
My fuel/exhaust mods are as follows:
Walbro 190
Jim's Fuel Mod
330 Supra Injectors (non-turbo)
Return Style Fuel Rails
OBX Headers & Y-pipe
OBX SRI w/ CAI
Custom Catback w/ 2 TRD Mufflers
NEO AFC
Any help or guidance is highly appreciated. Thank you in advance.
SpeedySolara
Postby trd4life » Sat Sep 26, 2009 5:34 pm
put your low throttle settings as -10% across the boards. Leave your high throttle settings at 0
Postby jetbtkng » Sat Sep 26, 2009 5:38 pm
500 rpm minus 9, 1000 mins 9, 1500 minus 9, 2000 minus 9, 2500 minus 7 3000 minus 5, 3500 minus 3, 4000 minus 2, 4500 i think theres two settings top minus 5, bottom minus 1, 5000 minus 7, 5500 minus 10, 6000 minus 12, this is what i wrote down when i changed my afc to a neo, it should get you by, dont hot rod it.................... :drinking:
Postby jetbtkng » Sat Sep 26, 2009 5:40 pm
ya just listen to gabe, he knows more than i do.................... :drinking:
Postby SpeedySolara » Sat Sep 26, 2009 5:45 pm
Thank you for the fast replies. I will try these settings and see how my car responds. Any others?
SpeedySolara
Postby jetbtkng » Sat Sep 26, 2009 6:09 pm
you dont need anything else, this should get you to the dyno shop, and get there asap, cause >>I'm a douche<< can break, no hot rodding at all, i know because we blew bbq bob knock sensors when we put a 5.5 pully on his camry.................. :drinking:
Postby ASG14 » Sat Sep 26, 2009 6:41 pm
BTW, I'm doign the work with him. I made a knk relocation bracket and got a new harness for safety.
ASG14
Postby ASG14 » Sat Sep 26, 2009 6:42 pm
jetbtkng wrote:you dont need anything else, this should get you to the dyno shop, and get there asap, cause >>I'm a douche<< can break, no hot rodding at all, i know because we blew bbq bob knock sensors when we put a 5.5 pully on his camry.................. :drinking:
I blew 5 at 4PSI, lol.
ASG14
Postby SpeedySolara » Sat Sep 26, 2009 7:17 pm
Freaking animal! Only you would blow 5 knock sensors at 4psi LOL Frank I totally agree with you, NO hot rodding for me...I'm going to play it safe and take it easy. Thanks to Adam I have a lot of work done to my car, thanks man.
SpeedySolara
Postby Dawgz » Sat Sep 26, 2009 9:27 pm
I suggest u leave the safcII initialized, meaning its not adjusting anything.
Driving to the dyno shop at under 3k should be just fine....dont push it after u put the injectors in, until you get a tune.
Postby akora12 » Sun Sep 27, 2009 6:52 am
Dawgz wrote:I suggest u leave the safcII initialized, meaning its not adjusting anything.
This is exactly what I did and was fine.
Postby trd4life » Sun Sep 27, 2009 9:25 am
If you leave your low throttle settings at 0% with the bigger injectors, you WILL run super rich and trash your plugs.
Postby akora12 » Sun Sep 27, 2009 10:11 am
I can't vouch for every situation, but my ecu handled 325cc injectors just fine a low throttle. I have the dyno specs somewhere.
Postby ASG14 » Sun Sep 27, 2009 10:26 am
He has to drive like 2 hours to the dyno shop......
ASG14
Postby Dawgz » Sun Sep 27, 2009 11:22 am
ASG14 wrote:He has to drive like 2 hours to the dyno shop......
2 hours should be nothing.
Return to Forced Induction
Users browsing this forum: No registered users and 98 guests
