SolaraGuy.com • View topic - New find...Old Article on TRD Solara with Dyno graph!
Postby RON » Sun Oct 04, 2009 3:01 am
I've never seen this particular article....interesting! They show 4.5Lbs boost here.
http://www.turbomagazine.com/tech/turp_0110_aftermarket_bolt_on_turbo_supercharger_kits/trd_toyota_solara.html
Standard Kit Boost:
4.5 psi
Turbo Magazine Dyno Tested Output @ Wheels:
233.2
[/img]
RON
Postby Dawgz » Sun Oct 04, 2009 5:01 am
that must have been REAL early...cause they did play around with what boost to put the SC kit out with....
Postby Eye8Pussies » Sun Oct 04, 2009 10:31 am
wow...good find. good to see some independent testing from back in the day.
And the numbers look pretty realistic for a 5-speed since the numbers are old and before they started correcting to sae numbers (usually around minus 5-10%).
Postby CamryOnBronze » Mon Oct 05, 2009 6:07 am
haha, my friend gave me this issue of Turbo Magazine a year or two ago when I had my solara- pretty cool.
Postby trd4life » Fri Oct 09, 2009 4:51 am
Interesting. The Original s/c kits came with a 3.2" pulley which makes 4.5psi
The later revised kits came with a 3.4" pulley which makes 3-4psi.
Postby GreenSolara01 » Sun Oct 11, 2009 5:10 pm
Why would they want to put out less power on the kit?
GreenSolara01
Postby Akfahad » Sun Oct 11, 2009 5:17 pm
turns out that Gabe and I discovered I have one of the original SC setups with the first set of pulley's...pretty interesting
Return to Forced Induction
