SolaraGuy.com • View topic - Pulley info
Pulley info
Pulley info
Postby RON » Mon Oct 26, 2009 9:00 pm
First off ,check this out....pulleys that minimize slip. You're going to definitely increase belt slip with smaller pulleys (undectable, except for loss of boost). This place can also MODIFY your own pully!
http://www.reichardracing.com/pulleys.php
Ultra Grip Pulley
Get rid of your Blower Slippage problem with our new ultra grip pulleys. Availible in 6, 8, 10, and 12 rib. We can modify your pulley or custom manufacture. Patent applied for. Call for details.
Now Available for ProCharger Ford and GM,.>>> Eaton<<<, 03' Cobra, Gen 2 Lightning, Magnusun Corvette, Whipple, Saleen Stage 1-4, Kenny Bell, Paxton, Vortech, Ford, and GM.
Another link:
New Reichard Racing designed, Non-Slip Grooved Pulleys (2.76", 2.93" and 3.10") "Patent Pending"
http://www.billetflow.com/supercharger_pulleys.htm
[/b]
RON
Postby RON » Mon Oct 26, 2009 9:57 pm
More pulley stuff..
Want to REALLY know your pulley size? Take a look>>
Here's what you do. Take a measuring tape (better with mm, then convert) and tightly wrap it around the middle of the pulley itself. Yes..you'll need it *in your hands" or take the belt OFF. This will give you the circumference around the ridges. Divide by 3.14>>BINGO! There has been some debate as to what the STOCK pulley is, since many were marked *3.4"*. Mine is :wink: . Well, I used this method and>>>the diameter according to the drawing above (ridge to ridge) is >>>>>3.2"!
RON
Postby Akfahad » Mon Oct 26, 2009 10:12 pm
nice find!
Postby jetbtkng » Mon Oct 26, 2009 11:31 pm
underdog pullies are designed the same, i have 3 of them, 6,7,8 lb, i dont know if you knew that, wonder if they would make 2.4 in pully........... :drinking:
Postby akora12 » Tue Oct 27, 2009 5:20 am
Nice find, especially since URD doesn't make the supergrip pulleys for the M62 anymore.
Return to Forced Induction
