SolaraGuy.com • View topic - Boost question
Boost question
Boost question
Postby RON » Tue Oct 27, 2009 4:38 pm
Does anyone here get Max boost in 2nd? I can't. I get 4.5 lbs max...5+ in 3-5th. I have 5.5lb pulley, but Max I get is around 5.2Lbs on the VDO gauge I just installed.
RON
Postby RON » Wed Oct 28, 2009 1:20 am
Think this may answer my question...it's about a turbo car, but I think it applies to SC cars as well? They say Turbos are "Load" dependent and SC cars are RPM dependent...but I'm pretty sure our SC is load related as well. If it was RPM, then reving the car in neutral would produce boost that's RPM dependent.... which it doesn't (very little).
http://www.mazda-speed.com/forum2/index.php?topic=18637.0;wap2
It's more about engine loading than time in gear.
Turbo's build higher boost the more loaded the engine is.
In lower gears your torque is multiplied by the transmission, so there is less load per revolution on the engine. In higher gears each engine revolution has to do more work. This causes the turbo to output more and more air while the engine is spinning more slowly, resulting in a higher boost pressure.
RON
Postby 1gSE » Wed Oct 28, 2009 1:23 am
don't quote me on this, but i remember this came up a while ago and someone said something along the lines of it gradually making more boost in later gears because of traction issues
Solara-M62 @ 5.5psi
1gSE
Postby chaneytsai » Wed Oct 28, 2009 11:29 am
I think boost is liner by RPM if actuator is not connected to vacuum source. With actuator working, it opens bypass valve to release boost when not in full load. That's why you don't see any boost in P or N. Keep in mind, EBC cuts boost in first gear too.
You can try to disconnect actuator vacuum hose and see what happen. By doing this you are boost all the time so be careful for lean condition. Castro has tried this but he has URD MAP box.
Here is his post
http://www.solaraguy.com/viewtopic.php?t=45275
chaneytsai
Postby RON » Wed Oct 28, 2009 11:44 am
chaneytsai wrote:I think boost is liner by RPM if actuator is not connected to vacuum source. With actuator working, it opens bypass valve to release boost when not in full load. That's why you don't see any boost in P or N. Keep in mind, EBC cuts boost in first gear too.
Here is his post
Yes..that's the key. It becomes load dependent because of the BYPASS VALVE. For example, If you're COASTING down a hill with light throttle in 3rd at 4000 RPM,
there's no load and the bypass valve isn't shut...so no boost. I think in second, there just isn't enough load to fully shut the valve as it would in say 5th at 3000 RPM. I can easily get Max boost in 4th or 5th by flooring it
at 3000 RPM!
RON
Postby jetbtkng » Wed Oct 28, 2009 12:31 pm
have you bypassed the boost bottle ron, so you get instant boost, just wondering................ :drinking:
Postby RON » Wed Oct 28, 2009 12:58 pm
jetbtkng wrote:have you bypassed the boost bottle ron, so you get instant boost, just wondering................ :drinking:
??..Not sure what you mean...the By Pass Valve? I get instant boost in all gears, it's just that I don't MAX in second (or third most of the time). I wouldn't modify the By Pass Valve, since I don't want boost in off load/low load conditions.
RON
Postby RON » Wed Oct 28, 2009 3:48 pm
Ok :oops: ....turns out I can JUUUUUST BARELY hit Max boost (5Lbs +) in second right at red line when the rev limiter kicks in. Doesn't always happen though. It's VERY easy to get Max in 4/5th and MUCH lower in the RPM range too. So, load does make a big difference.
RON
Postby CASTRO » Wed Nov 04, 2009 10:50 am
Here is his post
Still running it DD with no line attached to the actuator and all is well. I think what helps is the URD box to sense boost and go into open loop faster. Def more power everwhere in the RPM range.
Somethings I've noticed:
-There is still vacuum but likes to stay close to 0 as soon as you give it a little bit of throttle.
-Drivability seems better and gas consumption hasnt really changed. At times it seems to be higher than before.
CASTRO
Return to Forced Induction
Users browsing this forum: No registered users and 262 guests
