SolaraGuy.com • View topic - EGR valve - Insufficient egr flow
Postby 99V6solaraSE » Fri Nov 20, 2009 9:55 am
So when i put on the supercharger, i just modified my stock egr pipe initially to fit. I initially thought that was the reason for my CEL for insufficient egr flow since one end was kinda pinched off where i bended it to make it fit. I eventually found an auto egr pipe and the CEL still came back. The car idled really low too and started to shake every time i was at a stop on D so i always popped the car into neutral.
Now I just replaced the entire egr valve after buying one for 160$ and it still came back. The idle is back to normal though.
In fact in the process, I must've done something else cuz I also have the "system too lean - bank 1" code.
99V6solaraSE
Postby trd4life » Fri Nov 20, 2009 10:00 am
Are there any performance shops in your area that specialize in toyota?
Postby 99V6solaraSE » Fri Nov 20, 2009 10:10 am
not that i know of... And i just noticed when i took my intake out, there was a lot of oil.. In fact i had to buy a new filter since my filter was soaked in oil.. Not a good sign from what Ive been reading.. Possibly blow-by?
99V6solaraSE
Postby ASG14 » Fri Nov 20, 2009 10:10 am
Sensor on top likely bad. It;s common. Dawgs had to replace his, so I pulled one from the junkyard.
ASG14
Postby 99V6solaraSE » Fri Nov 20, 2009 10:11 am
ASG14 wrote:Sensor on top likely bad. It;s common. Dawgs had to replace his, so I pulled one from the junkyard.
i replaced that first.. and i still got the egr light.. so thats why i ended up replacing the whole egr valve and still have the same issue.
99V6solaraSE
Postby ASG14 » Fri Nov 20, 2009 10:19 am
Well, the only thing left is the VSV I think. That, and the vacuum lines.
ASG14
Postby trd4life » Fri Nov 20, 2009 10:21 am
if your intake is full of oil thats not good
Postby 99V6solaraSE » Fri Nov 20, 2009 10:24 am
man i dont like where this is going.. and i was going to get a tune too.. guess im just gonna have to re-evaluate everything and see where i go from here.
99V6solaraSE
Postby GreeKAvaLoN » Sun Nov 22, 2009 11:30 am
same problem here.. I decided to just give up and go on to a gs..
GreeKAvaLoN
Re: EGR valve - Insufficient egr flow
Postby RON » Sun Nov 22, 2009 3:57 pm
99V6solaraSE wrote:So when i put on the supercharger, i just modified my stock egr pipe initially to fit. I initially thought that was the reason for my CEL for insufficient egr flow since one end was kinda pinched off where i bended it to make it fit. I eventually found an auto egr pipe and the CEL still came back. The car idled really low too and started to shake every time i was at a stop on D so i always popped the car into neutral.
It takes SEVERAL drive cycles to reset the code. A *DRIVE CYCLE* is starting the car from COLD. Try this first. There are also temp and position sensors. May have to replace those if light won't reset.
RON
Return to Forced Induction
