SolaraGuy.com • View topic - trouble trouble
trouble trouble
trouble trouble
Postby Driver2g » Fri Jan 15, 2010 6:25 pm
Need some help guys. Recently did a turbo install, and I keep getting a CEL P1346. Ive done some research and found that it refers to a cam/vvti sensor. I am running 6psi and using a AEM FIC. Any ideas of what could be causing this? If it is a sensor where is it located.
02 Solara 2az-fe TURBO!!!
trd lower springs
short shifter
rear brake conversion
TRD muffler
Driver2g
Postby 1gSE » Fri Jan 15, 2010 9:02 pm
Did you intercept the cam sensor or tap it? I'm not sure about the 2AZ, but when I intercepted the cam sensor wire with my FIC, the ecu didn't like it at all. Double check the wiring. Plug the bypass harness in an see if you still get it.....but stay out of the go pedal
Solara-M62 @ 5.5psi
1gSE
Postby sahuddleston » Sat Jan 16, 2010 8:33 am
never had this issue when i boosted my 2az. i had a CEL but i ended up removing the bulb as it was just my 02 sensor being removed. good luck finding it.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Return to Forced Induction
