SolaraGuy.com • View topic - Runnin lean.......
Runnin lean.......
Runnin lean.......
Postby Driver2g » Thu Feb 18, 2010 9:59 am
Aight guys I finally got my a/f ratio gauge so I've been doing some tuning. I fond that under boost I was running really rich, so I got that straight and am running right around 12.2/1 under boost. but when ever I let off the gas the gauge show that I'm running extremely lean. It doesn't matter if I'm coming out of boost or not, it does the same thing during normal driving. At idle I'm right around 14.2-14.6/1. Any ideas on what the problem could be? Any ideas would be greatly appreciated.
02 Solara 2az-fe TURBO!!!
trd lower springs
short shifter
rear brake conversion
TRD muffler
Driver2g
Postby Eye8Pussies » Thu Feb 18, 2010 10:02 am
does it go lean only when you get off the gas, or also when you are cruising?
your afr should go super lean when you are off the gas and there is no load, since the ecu was designed to save fuel for gas economy
Postby Driver2g » Thu Feb 18, 2010 10:22 am
It only goes lean when I let off the gas. While cruising its steady at 14.4/1.
trd lower springs
short shifter
TRD muffler
Driver2g
Postby Eye8Pussies » Thu Feb 18, 2010 10:55 am
then you're good, that's the way it's supposed to be!
Postby EricSol » Fri Feb 19, 2010 7:42 am
The ecu cuts fuel on deceleration. Most cars do this.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby Driver2g » Fri Feb 19, 2010 7:04 pm
Thanks for the info, its good to know that, thats not a problem.
trd lower springs
short shifter
TRD muffler
Driver2g
Return to Forced Induction
Users browsing this forum: No registered users and 278 guests
