SolaraGuy.com • View topic - CARB exemption papers for supercharger - CALIFORNIA ONLY
Postby trdkamuri51o » Mon Mar 29, 2010 11:09 pm
so i was bored checking what chargers have been ok'd by CARB nazi's for the g8 gxp (magnacharger is the only one for it now)
but while there i figured id pull up the links for the guys in CALIFORNIA to print and leave in their car if pulled over... u would be suprised in how much this can help you....
3.0 specific: http://arb.ca.gov/msprog/aftermkt/devic ... -425-6.pdf
all toyota:
http://arb.ca.gov/msprog/aftermkt/devic ... -425-9.pdf
due to the high amount of california drivers who are charged on this forum i think this should be stickied..
trdkamuri51o
Postby CASTRO » Tue Mar 30, 2010 10:45 am
nooice! i think i got those papers that came with the s/c too. i usually keep it handy just in case
CASTRO
Postby alltrac92 » Tue Mar 30, 2010 11:40 am
Cops around here only care about the EO sticker. Smogcheck inspections look for the same.
Read the bold print "The kit includes a a 3.2" diameter supercharger pulley and uses the stock crankshaft pulley" The supercharger is only exempt with this size pulley.
If a cop or CHP suspects illegal mods and you show him that paperwork you better hope your running a stock pulley.
alltrac92
Postby trd4life » Tue Mar 30, 2010 12:24 pm
the funny thing is MOST of the stock trd pulleys on members cars here are 3.4", that would really confuse the cop ,your running a lower boost pulley than stock haha
Postby Dawgz » Tue Mar 30, 2010 2:08 pm
alltrac92 wrote:Cops around here only care about the EO sticker. Smogcheck inspections look for the same.
I think URD makes smaller pulleys for the Toyota trucks but are stamped with the stock size.....
Postby ASG14 » Tue Mar 30, 2010 2:12 pm
^ The PulleyBoy's ones are not, hehe. But yeah, your right on the URD ones.
Nice find trdkamuri510!
ASG14
Postby alltrac92 » Tue Mar 30, 2010 2:22 pm
I'm starting to think the bigger pulley might not be bad considering the 91 craptane piss gas we have here.
I'm curious about the standard pulley sizes.
Toysport list
pulley size/boost
3.6/ 2.0psi
3.4/ 3.0psi
3.2/ 4.0psi
Pulley Boys
3.2/ 3.0psi
3.1/ 3.5psi
3.0 / 4.0psi
Then you have the CARB document saying the TRD supercharger 3.2 is for 6 PSI.
Does anyone have the definitive answer?
alltrac92
Postby jetbtkng » Tue Mar 30, 2010 2:27 pm
most sc'ers when at high rpm's boost more, so if its 3 psi, at 6000 rpm's it might get to 5 psi................. :drinking:
Postby JimKing » Tue Mar 30, 2010 4:12 pm
jetbtkng wrote:most sc'ers when at high rpm's boost more, so if its 3 psi, at 6000 rpm's it might get to 5 psi................. :drinking:
Seems to be the case with the TRD SC. Datalogging on a 1mz/3mz hybrid shows (with the stock pulley) you get 2.5psi till about 4500rpm, then boost ramps up to 4.5psi at redline. On a normal 1mz those number would be somewhat higher, of course.
JimKing
Return to Forced Induction
