SolaraGuy.com • View topic - noise
noise
noise
Postby 5842solara » Fri Apr 02, 2010 4:41 pm
hey, i just installed a supercharger.. i dont know if it even works though..
well.. there is a noise coming for the sc.. i think the pulley side maybe.. it has the whine that sc makes but its an ugly whine. how do you lubricate the sc? do you put oil.. i know its pre lubed but can you add more? thanks
or.. is the sc just broken?
5842solara
Postby GzNutz » Fri Apr 02, 2010 4:51 pm
Can you post a vid?
Postby 5842solara » Fri Apr 02, 2010 5:00 pm
i can try, not sure how though. i dont have a youtube account or anything.
well i have to go to the store though to get o rings.. my injectors leaking. i dontk now when i can take vid.
um.. also
i read that the ebc cuts boost from 1st to 2nd... it helps the trans from breaking? (automatic) but what about standard cars? do i need the ebc on a standard car?
5842solara
Postby 5842solara » Sat Apr 03, 2010 12:55 am
thanks Gznutz, but i found the problem..
after i fixed the fuel leak, i was able to run the car.
the tension pulley is moving a lot. and when i hold it by hand it kinda goes away.
5842solara
Postby jetbtkng » Sat Apr 03, 2010 1:24 am
maybe your belt is to big, try a size smaller................. :drinking:
Postby 5842solara » Sat Apr 03, 2010 2:55 pm
I dont think its the belt though. because the squeaking sounds like the bearing is no good. and the tension is preetty good..
5842solara
Postby 5842solara » Sat Apr 03, 2010 4:51 pm
ah stupid.. it was hitting the stock stud from the old motor mount bracket. but damn im running lean and egr sensor circuit code is coming up
5842solara
Postby ToyoSolV6 » Sun Apr 04, 2010 4:53 pm
get tuned kid!
cnt run lean, your gonna hurt something....FAST!
Postby 5842solara » Sun Apr 04, 2010 5:27 pm
ToyoSolV6 wrote:get tuned kid!
yeah.. im trying to find a safc.. but i dont want to spend like 2 or 3 bils on ebay..
5842solara
Postby jetbtkng » Sun Apr 04, 2010 5:31 pm
well thats what there going for, if u look hard enough u might find one for about $150-175, but i wouldnt run without it very long........... :drinking:
Postby 99BlackSandv6 » Sun Apr 04, 2010 6:02 pm
You're probably leaking air through the EGR piping. That will throw the code, and cause very lean conditions. Check all your mating surfaces and gaskets, make sure it's all buttoned up tight.
Postby 5842solara sc » Tue Apr 06, 2010 1:01 am
99BlackSandv6 wrote:You're probably leaking air through the EGR piping. That will throw the code, and cause very lean conditions. Check all your mating surfaces and gaskets, make sure it's all buttoned up tight.
hmm.. I did some re-hosing.. The supercharger has 1 diagram on hosing..
and the ebc wiring diagram had another. I did it the ebc way and now the code went away.
5842solara sc
Return to Forced Induction
Users browsing this forum: No registered users and 265 guests
