SolaraGuy.com • View topic - FIC Wiring
FIC Wiring
FIC Wiring
Postby Driver2g » Sat Apr 17, 2010 8:52 am
I found this diagram for the TC, but changed it a little so that the connections match the ecu for the Gen 1.5 solara. Hopefully it will help someone out, I know it would have made my life a lot easier when I was doing my install.
02 Solara 2az-fe TURBO!!!
trd lower springs
short shifter
rear brake conversion
TRD muffler
Driver2g
Postby Tony the Tiger » Mon Apr 26, 2010 6:59 am
Thanks for sharing... Did everything work properly after you wired up the AEM FIC?
Dynamotorsports Tuning
Tony the Tiger
Postby Driver2g » Mon Apr 26, 2010 7:18 pm
The only thing I ended up needing to do is wire in (2) 2.2k resistors. I found detailed instructions on the AEM forum on were to put them. Has something to do with the way our cam pos. sensor work.
trd lower springs
short shifter
TRD muffler
Driver2g
Return to Forced Induction
Users browsing this forum: No registered users and 262 guests
