SolaraGuy.com • View topic - Tuning options?
Tuning options?
Tuning options?
Postby usoff89 » Wed Apr 21, 2010 3:49 pm
Ok, so I've done some reading and am looking for some more info on tuning options for our cars. I know about the safc, and piggy back set-ups. Are our cars tunable like say a LS1 camaro, etc?
Or does anybody know of a true tuning source. I'm not looking to tune just yet, but when I do it would be nice to atleast know the best option.
Thanks, Mike
99 SuperCharged Lara
14.7@93 on 1/4mile (average)
Fastest run so far - 14.65@93
4.5psi
usoff89
Postby trd4life » Wed Apr 21, 2010 4:17 pm
easiest an most effective for our cars is the split second FTC piggyback. Out ECU's cannot be flashed or rechipped like other cars.
Postby GreeKAvaLoN » Wed Apr 21, 2010 5:25 pm
safc is probably easiest and most common, i have 2 for sale too :)
safc2 and the 1st gen, send me a pm if ur interested. im selling one or the other, not both.
GreeKAvaLoN
Postby trd4life » Thu Apr 22, 2010 8:08 am
greek it sounds like this guy wants something more advanced.
gabe
Postby 1gSE » Thu Apr 22, 2010 8:33 am
AEM FIC, but you'll probably get a CEL. I get 3..random misfire and #3 and 5 cyl misfire..but its not, and it's wired correctly. You can't hook up the cam sensor wire and the crank sensor. IIRC I have the cam sensor wires only. I got a topic somewhere about it
Solara-M62 @ 5.5psi
1gSE
Postby Eye8Pussies » Thu Apr 22, 2010 11:43 am
EManage ultimate
Postby EEngineer » Thu Apr 22, 2010 3:22 pm
e-manage ultimate x2
i'm running it..gained 10whp running NA
best piggyback before a standalone
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby Driver2g » Thu Apr 22, 2010 5:24 pm
1gSE wrote:AEM FIC, but you'll probably get a CEL. I get 3..random misfire and #3 and 5 cyl misfire..but its not, and it's wired correctly. You can't hook up the cam sensor wire and the crank sensor. IIRC I have the cam sensor wires only. I got a topic somewhere about it
If you use a the 2.2k resistor method, you get now misfires and no cel's. Go on the aem forum and do a search for it you can find some good instructions on how to do it. I have it and have no problems.
02 Solara 2az-fe TURBO!!!
trd lower springs
short shifter
rear brake conversion
TRD muffler
Driver2g
Postby usoff89 » Thu Apr 22, 2010 6:02 pm
A piggy-back setup will work fine for what I'm running on now. But, one day I'd like to have a built motor in the car and most likely a turbo setup. I was just thinking that we should have some more options for our cars! :-?
4.5psi
usoff89
Postby 1gSE » Thu Apr 22, 2010 6:36 pm
I'll have to check that out. I asked there and none answered, but i think I remember seeing something about using resistors
Solara-M62 @ 5.5psi
1gSE
Postby 99BlackSandv6 » Thu Apr 22, 2010 7:14 pm
Hey Eye8 and EEngineer,
Greddy shows two different harnesses for the 1MZ. Did you guys use the one with the T20 or T23 connector. Or do you need both?
EEngineer, I know you have the 3vz. Are you using a 1MZ harness?
Postby EEngineer » Thu Apr 22, 2010 8:56 pm
^there's an universal harness for the e-manage ultimate. just have to do some custom wiring.
EEngineer
Postby trd4life » Thu Apr 22, 2010 10:59 pm
EEngineer can you increase the rev limiter with the ultimate?
Postby EEngineer » Sat Apr 24, 2010 12:50 am
^i don't think so, afterall it's an piggyback and it uses the stock ecu to drive the signals, emanage just modifies the signals.
but i can confirm that with tony and see if he got ways to cheat around it lol
EEngineer
Postby trd4life » Sat Apr 24, 2010 6:27 am
The emanage ultimate has a rev limiter bypass feature which works well on the nissans, but your right i don't think we can use that feature on the toyota ecu.
Return to Forced Induction
Users browsing this forum: No registered users and 265 guests
