SolaraGuy.com • View topic - Need a few suggestions-air flow sensor setting on a emanage
Postby STYLSH » Sat Apr 24, 2010 10:41 pm
I've wired the emanage blue in now. No error codes from the emanage. However there are these rotory dials that sets what type of air flow sensor is on the car. Car idles fine with the current setting of 2-5 but once you hit boost, completely loses power. What settings do you guys have?
btw, I've got a gen4.5 1mz.
STYLSH
Postby trd4life » Sat Apr 24, 2010 10:50 pm
PM tony the tiger. he may take a couple days to reply he is super busy but he will get back to you and he does have the answer for sure.
Postby STYLSH » Sat Apr 24, 2010 10:55 pm
Out of curiousity why does it completely lose power when it hits boost.
STYLSH
Postby EEngineer » Sat Apr 24, 2010 11:28 pm
well, i run the emanage ultimate, however my airflow sensor is the AFM, which is a flap type sensor.
on my emanage i use the TY_FL2 which stands for Toyota Flap type2
however there are only 4 types, Hotwire, Pressure, Karman and Flap
I'm not sure if the MAF is classified as Hotwire or not, but it's definitely not flap or or pressure.
There are only 6 different types of Toyota Hotwire options, i guess try them out...and while ur at it, send tony a pm
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby STYLSH » Sat Apr 24, 2010 11:40 pm
Ahh now i understand what Tony means by trial an error. I think I need to trial and error 2-2 all the way up to 2-6. Supraa have map sensors as does us it seems so 2 should be right.
Would it damage the engine if it's wrong though as it seems the only way to test it is if it works properly at boost?
STYLSH
Postby EEngineer » Sun Apr 25, 2010 12:57 am
just watch your wideband to not go superlean =]
EEngineer
Re: Need a few suggestions-air flow sensor setting on a eman
Postby SpeedySolara » Sun May 30, 2010 11:57 pm
OMG...this is language is almost as hard to understand as when I started seeing more letters than numbers in math class. I'll try to keep up... :oops:
SpeedySolara
Postby JavaJoe_2 » Mon May 31, 2010 6:42 am
Try TY_HW-4
Got Boost?? :sweet:
JavaJoe_2
Postby argon18 » Fri Jun 18, 2010 8:22 am
Hmmm.... Anthony you should let them know how you went!
argon18
Postby STYLSH » Fri Jun 25, 2010 12:50 am
Ok, it kinda went well. Using the TY-HW 5 atm. The australia ecu's seems to be slightly different to the ones in the states. They ran the car fine with the supra injectors and 5.5psi, no super rich idle problems, as a matter of fact the first run was actually at the stoich ratio until top end. The car also didnt like anyone touching the timing. It left an "ignition malfunction code" when the emanage was plugged in to alter it and the car wouldnt start properly. So its only using the emanage for fuel atm, but with a lot more settings than what a SAFC would be able to provide.
The car is putting out 172kw atw on an unadjusted graph.
STYLSH
Return to Forced Induction
