SolaraGuy.com • View topic - Changing the SC pulley?
Postby usoff89 » Fri May 28, 2010 9:11 pm
What is the best way to take off the stock TRD pulley? I've tried a couple things but no luck. Any tips, or tricks that are recomended?
Thanks
99 SuperCharged Lara
14.7@93 on 1/4mile (average)
Fastest run so far - 14.65@93
4.5psi
usoff89
Re: Changing the SC pulley?
Postby JavaJoe_2 » Sat May 29, 2010 7:19 pm
Many say they just hit it with an impact to spin off the nut.
I prefer a strap wrench to hold the pulley.
I think either would suffice.
Then, I just use a standard pulley puller.
Got Boost?? :sweet:
JavaJoe_2
Postby usoff89 » Sat May 29, 2010 11:59 pm
Well, I didn't have either. So I took the old supercharger belt I had and used it to hold the pulley. It worked great! I now have the new 4.5psi pulley on it.
4.5psi
usoff89
Postby bbq bob » Fri Jul 30, 2010 5:19 pm
i had to heat it with a torch popped rite off.....
bbq bob
Postby ToyoSolV6 » Wed Aug 04, 2010 5:43 pm
Greg, Frank and I beat it with a 2x4 on the opposite side till it came off lol
Thats when i had the 4.5psi pulley.
Postby hskrsolara » Sat May 21, 2011 2:15 pm
impact with a flexible joint is easiest to spin the nut off. I also used a Ridgid strap wrench to hold the pulley still (home depot brand, consensus best strap wrench on the plumbing forums :)).
The tough part is actually getting the pulley off of the keyed shaft. I went to Autozone and rented an A/C compressor pulley puller. It is a tight space, but eventually worked. Almost impossible to avoid scratching the pulley and engine bay, it's so damn cramped and pulley pullers are rarely small.
hskrsolara
Return to Forced Induction
