SolaraGuy.com • View topic - Supercharger for toyota tacoma?
Postby Twin Turbo » Fri Aug 06, 2010 7:32 pm
So i realize this is a solara forum, but being a bunch of toyota guys i thought you might help me out here. I have been taking a pretty hard look at an 06' Toyota tacoma. Its the four door crew cab model with a short box. The truck is the TRD sport edition, black, and totally stock. Alot of potential when done right im hoping. Anyway, does anyone have any idea what kind of aftermarket upgrades are available for this truck? Id like to lift it a couple inches, put some pretty aggressive rims and mud tires on it, fender flairs and either extra leaf springs or airbags in the back end so i can still haul or tow some stuff. Is there a bolt on supercharger for these engines? Give me some ideas here guys
Follow @ballsofthunder for non-stop ridiculous action
Twin Turbo
Re: Supercharger for toyota tacoma?
Postby chullen1 » Sat Aug 07, 2010 1:22 am
Only if it is a 4.0 V6 if not then you are out of luck on the supercharger.
chullen1
Postby GzNutz » Sat Aug 07, 2010 2:26 pm
http://www.urdusa.com/product_info.php?cPath=168_2&products_id=1260518946
From urdusa.com
The Stage I Kit is a MKII kit installed on a completely stock truck. It includes:
80mm pulley
5700 RPM limit
URD's 2005 XRunner dyno results showed 337 RWHP and 315 RWTQ at 5700 RPM & approximately 7 PSI of boost
Stage II is achieved by adding:
75mm pulley
New Stage II calibration file for the X-1 engine management system
Doug Thorley Long Tube Headers
URD Competition Y Pipe
URD 3" Cat-Back Stainless Exhaust
URD's 2005 XRunner dyno results showed 382 RWHP and 352 RWTQ at 5900 RPM & approximately 8.5 PSI of boost
Stage III is achieved by adding the following to Stage II upgrades:
70mm pulley
New Stage III calibration file for the X-1 engine management system
Installing the Grill Craft MX Series grill to improve airflow over the front mount intercooler.
93 octane recommended, however highest power levels will be obtained by using high octane unleaeded race gas
URD's 2005 XRunner dyno results showed 400+ RWHP and 382 RWTQ at 6200 RPM & approximately 10 PSI of boost
It seems there's plenty of potential.
Postby JavaJoe_2 » Sun Aug 08, 2010 7:48 am
:roll: http://www.trdusa.com/partscatalog.cfm? ... cle=tacoma :roll:
I think all the "crew cabs" had the 4.0
Got Boost?? :sweet:
JavaJoe_2
Postby trd4life » Mon Aug 09, 2010 9:07 am
i can get you any part under the sun for tacomas!
Postby Akfahad » Tue Aug 10, 2010 4:59 pm
^^Gabe's the man; Underdog Racing is also a good site.
Return to Forced Induction
Users browsing this forum: No registered users and 100 guests
