SolaraGuy.com • View topic - Dyno Prediction of my 3mz/1mz
Postby Gregtrd » Wed Nov 10, 2010 9:05 pm
Here's my mods list, let me know what you ladies think I'll put down WHP wise, I should be at least 300whp. Church's will be the place where I'll Dyno.
-3.3 3mz/1mz engine 9.8to1 compression
-Double stack MLS headgasket
-ARP head bolts torque @ 85 ft.lbs
-URD Crank pulley
-Trd Supercharger 9psi (2.2)
-Injen/UPFD extension
-8.5mm Magna core wires
-JPP headers
-3" OBX cat back
-MSD DIS 4
-Split sec. FTC-1
-Zitronics wideband
-Snow Performance water/meth injection 625ml nozzle
-Fidenza flywheel
-Spec clutch stage 2
-TRD thermostat
-TRD radiator cap
-return style fuel setup with supra FPR
-walbro 255 fuel pump
-IK22 plugs
-330cc supra injectors
-supra maf sensor
-GM knock sensors
-O2 sim
-split sec esc1
-yellow top optima battery
-jet performance throttle body spacer
-KAAZ LSD 1.5
-TWM short shifter
-Greddy weighted shift knob
-Jims torque rod
-rear soild engine mount
-24mm Front and 20mm rear whiteline sway bars
-front lower control arm energy suspension bushings
-rack & pinion superpro bushing
-Dog bone superpro bushing
-rear tailing arm energy suspension bushings
-Jic coilovers
-Stop Tech BBK 4 piston calipers and 13" rotors two piece
-17x8 TSW Revos 235/45/17 DZ101 Dunlops tires
-TRD lip kit.
Well I still have more to add to the list but not important to the dyno tune. I got a little carried away with the list already.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: Dyno Prediction of my 3mz/1mz
Postby mig0s » Wed Nov 10, 2010 9:10 pm
I'm sure it's gonna be 312whp, for the torque, I'll take a guess, 301.
mig0s
Postby albertrd » Wed Nov 10, 2010 9:14 pm
where is the big stock power playas :think: Fergi.
albertrd
Postby SleeperSolara » Wed Nov 10, 2010 9:19 pm
:o
Postby sarki » Wed Nov 10, 2010 11:04 pm
Im going to put down 302 WHP with my 3.0 Auto beeaatch! BTW who the hell is Fergi???? He aint no Power Playa!!!! OH Shizzle.
Who wants to buy it?
sarki
Postby DSM_Lara » Thu Nov 11, 2010 1:06 am
lol
DSM_Lara
Postby Gregtrd » Thu Nov 11, 2010 11:01 am
DSM_Lara wrote:lol
your solara looks clean.
Gregtrd
Postby crispone » Thu Nov 11, 2010 11:10 am
What fuel are you running???
On pump (93) or up to 100 octane or so, I'd put you at:
290rwhp +- 5% (approx. 275~305)
Purely speculative... but based on what OTHERS have achieved with similar array...
Good luck!
Postby mig0s » Thu Nov 11, 2010 11:15 am
crispone wrote:What fuel are you running???
Good luck!
Don't forget that he's a 3.3L, not 3.0 :P
mig0s
Postby Gregtrd » Thu Nov 11, 2010 11:55 am
Good luck!
I'm going to run 95.1 octane. mixing 3.5gals of 110 and 12.5gals of 91 to get 95.1octane. also not running any cats.
Ive set up bbq bobs and franks(jetbk) camry/solara. Im running the parts they got and some. frank and bbq bob run 94.5octane
I might run 97octane but not sure if its necessary.
Gregtrd
Postby crispone » Thu Nov 11, 2010 11:58 am
Good luck!
Add 10% of absolute displacement increase ratio accordingly:
3.0/3.3=8.1% displacement increase x 10% = 0.81% absolute increase = 275~305 x 100.81 = 277~308
CORRECTION VALUE for 3.3l -vs- 3.0l:
277rwhp ~ 308rwhp :wink:
Postby crispone » Thu Nov 11, 2010 12:04 pm
Good luck!
I feel pretty good about my guesstimate. Of course... do you have any STICKERS on the car??? 8)
Postby Gregtrd » Thu Nov 11, 2010 12:06 pm
Good luck!
stickers?
Gregtrd
Postby trd4life » Thu Nov 11, 2010 12:12 pm
greg i think if the compression drop doesn't affect you too much that 333whp is possible.
Postby Gregtrd » Thu Nov 11, 2010 12:14 pm
frank and bbq bob are running 7lbs and a 375ml nozzle of water/meth and I'll be running 9lbs with a 625ml nozzle water/meth. sarki is running 550ml meth nozzle with no quenching.
Gregtrd
Return to Forced Induction
