SolaraGuy.com • View topic - just dynoed
just dynoed
just dynoed
Postby Sp33d » Fri Nov 12, 2010 5:32 pm
should have done it the first time...but i finally bit the bullet after several failed attempts at tuning here in northern california and drove down to so cal to visit church's auto tuning. what an amazing group of guys. new numbers....
282.5hp/255.4 ft.lb of torque.
needless to say...im happy and suggest this place to ANYONE that is tuning. take a drive...you wont regret it. im too lazy to post mods...but i was running a return style fuel system..thanks trd4life and 375ml methanol injection...thanks gregtrd.
-sp33d
Sp33d
Re: just dynoed
Postby Gregtrd » Fri Nov 12, 2010 5:38 pm
Let me know when you're ready for the 300whp, Ill set you up.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: just dynoed
Postby trd4life » Sat Nov 13, 2010 5:01 pm
wow huge #'s for 6psi!
Re: just dynoed
Postby stringbean » Sat Nov 13, 2010 6:04 pm
very nice for 6psi!!! cant wait till i can pull # like that!
stringbean
Re: just dynoed
Postby SirThomas88 » Tue Nov 16, 2010 10:25 am
very nice numbers! sounds like you're running very well.
now take it to another dyno shop to see if Church's is accurate :p I've heard some rumors...
SirThomas88
Re: just dynoed
Postby trd4life » Tue Nov 16, 2010 11:35 am
Its not that Churches is really inaccurate i think its just that HUB dynos such as theirs typically read higher than other dynos.
Re: just dynoed
Postby hskrsolara » Tue Nov 16, 2010 6:51 pm
trd4life wrote:Its not that Churches is really inaccurate i think its just that HUB dynos such as theirs typically read higher than other dynos.
recalling previous "discussion", I believe the consensus was that hub dynos read 5-10% higher than a standard chassis dyno. good numbers either way.
hskrsolara
Re: just dynoed
Postby Sp33d » Tue Nov 16, 2010 7:06 pm
i prepaid for one dyno tune up here in northern california..he runs a dynpack as well. in fact, same as the one churches runs. so i will let you guys know soon enough.
-sp33d
Sp33d
Re: just dynoed
Postby trd4life » Wed Nov 17, 2010 11:51 am
If your going to dyno again on the same type of hub dyno your #'s should be the same as Churches. You would need to dyno on a dynojet or another type of roller dyno to see if the hub dyno actually does produce higher #'s
Re: just dynoed
Postby lemegacool » Wed Nov 17, 2010 5:08 pm
i'm real noob when it comes to dynos but i would think that the additional mass/drag caused by the wheels on a dynojet is the cause of why they read lower... might be wrong but thats my theory lol :P
1994 camry v6 5 speed swapped
custom m90 blower in progress
cardomain: http://www.cardomain.com/ride/3872430
lemegacool
Re: just dynoed
Postby trd4life » Wed Nov 17, 2010 8:41 pm
Its my understanding the roller type dynojets read higher than the hub style dynapacks...
Re: just dynoed
Postby SirThomas88 » Sat Nov 20, 2010 11:40 am
interesting. I had heard that the hub centric dynos are more accurate than roller dynos. Though I don't know whether that means they'd read higher or lower.
Next time I get dyno'd I'd like to go to both a hub centric and roller dyno on the same day so we can compare the two.
In any case, nice numbers Sp33d!
SirThomas88
Re: just dynoed
Postby Sp33d » Sun Nov 21, 2010 12:54 am
thought id post a video of how hard she pulls now. enjoy!
http://www.youtube.com/watch?v=YJChEP7hMRI
-sp33d
Sp33d
Re: just dynoed
Postby bbq bob » Sat Nov 27, 2010 3:34 pm
drum dynoes arent as accurate as a hub dyno, there are many variables, rim size, tire pressure, how tight its strapped down to the ground, & its never the same or consistant on a drum dyno, on a hub dyno the only thing that would change is ambient temps, & humidity, other than that its more accurate than drum dynoes, frank aka jetbtkng & me have been to churches & have seen improvements on a consistant basis, so who ever said they heard fishy things about churches is rediculious, my cars never ran so good, & ive been to other dyno shops & churches is the best shop by far...
bbq bob
Re: just dynoed
Postby Gregtrd » Sat Nov 27, 2010 4:51 pm
Well said bbq bob!
Gregtrd
Return to Forced Induction
Users browsing this forum: No registered users and 84 guests
