SolaraGuy.com • View topic - How much Nitro HP with stock fuel system???
Postby RAPIDITO » Fri Feb 25, 2011 8:10 am
Hi, I'm thinking on installed a nitrous system to my 04 Solara V6, but I want to know is the stock fuel system can supply enough to a 75-100hp shot. The car only have an short cold air intake, 2.5" cat-back with free flow Dynamax muffler.
RAPIDITO
Re: How much Nitro HP with stock fuel system???
Postby GzNutz » Fri Feb 25, 2011 10:51 am
Stock is fine for 75 as I haven't gone higher.
Postby RAPIDITO » Fri Feb 25, 2011 11:36 am
Do you have pics of your setup? Where is the best place to connect the fuel supply?
Any other mod needed? Spark plugs? Gap?
RAPIDITO
Postby GzNutz » Fri Feb 25, 2011 5:41 pm
I had the fuel rail tapped.
No other mod was needed. But I highly stress the importance of a window activated switch. Another gen2'er recently went about this without a window switch after being informed multiple times of its added safety. A few days after his install and his bragging of dyno numbers and not posting sheets, he mysteriously disappeared (http://solaraguy.com/viewtopic.php?f=46&t=50074&p=589761#p589761). I can only imagine the tranny or engine grenaded.
If you do some digging on here you should be able to find Mike T's arctic frost nitrous thread. Lots of helpful info in there. I will try to find it a little later to night and post the link if you can't find it.
Postby GzNutz » Fri Feb 25, 2011 6:30 pm
Postby RAPIDITO » Tue Mar 15, 2011 4:12 pm
Thanks GzNutz for the info. Which spark plugs do you recomend me and which gap? Are colder spark plugs are needed for a 75 hp shot?
RAPIDITO
Postby GzNutz » Tue Mar 15, 2011 4:28 pm
I just stuck with the stock plugs, they aren't adjustable and worked just fine. Gabe sugguested I use NGK part # bkr7e-11, they are colder.
Postby RAPIDITO » Tue Mar 15, 2011 4:34 pm
GzNutz wrote:I just stuck with the stock plugs, they aren't adjustable and worked just fine. Gabe sugguested I use NGK part # bkr7e-11, they are colder.
Ok thanks. Hope that this tranny hold the shot!
RAPIDITO
Return to Forced Induction
