SolaraGuy.com • View topic - supercharger tensioner
Postby 808lara » Fri May 06, 2011 5:54 pm
i have the old kazuma trd supercharger without the tensioner-is it possible to install a tensioner? any advantages or disadvantages?
808lara
Re: supercharger tensioner
Postby Budd81 » Fri May 06, 2011 6:20 pm
I was trying to get one for mine also, but was informed that they made 2 different kinds of plate set-ups. Mine is the old set-up, so i just tighten w/ the alternator. I ordered a used Kent-Moore Belt Tension Gauge off Ebay to keep it at the correct tension. From what I was told you would have to get the newer set-up if you want to install the Dynamic Tensioner. Dont know of any pro's or cons with it since I dont have one. From all the post ive been reading over the past few months since ive joined & had my charger installed im pretty certain you will get some info on this & i will be corrected if ive posted any mis-information.
99 Camry V6 5-speed S/C'd
Budd81
Postby Gregtrd » Fri May 06, 2011 9:47 pm
The tensioner pulley plate sucks, that pulley plate you have is the way to go.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby trd4life » Fri May 06, 2011 10:35 pm
i sell the updated tensioner style plates. If your interested in a set just shoot me a PM.
thanks
gabe
Return to Forced Induction
