SolaraGuy.com • View topic - headers drop boost pressure?
Postby hskrsolara » Sat May 14, 2011 3:50 pm
So, I've confirmed a drop in boost with my OBX headers. I lost about 1 lb on my 5.5 psi pulley (currently maxing out at 4.5 psi and spiking to 5 psi on my gauge) after I ditched the oem headers/dats y pipe/evo2 for the new OBX headers/OBX y pipe/OBX 3 in exhaust.
I've acquired that this is normal, for opening up the exhaust to drop boost slightly? I haven't made any other changes, just the exhaust system, and instantly lost .5-1 lb of boost. Planning on installing the 6.5 psi pulley to get back to 5.5-6 lb of effective boost and spike to 6.5 lb. Is this the right approach? Anyone else seeing the same thing?
hskrsolara
Re: headers drop boost pressure?
Postby corlon » Sat May 14, 2011 6:28 pm
i'm not boosted, but i know this is a common issue. makes sense. a buddy had the same issue with his supercharger mustang.
NiCe
corlon
Postby 1gSE » Sat May 14, 2011 7:35 pm
It'll happen. PSI is just resistance.You're still moving the same amount of air, you're just doing it more efficiently now that it breathes better
Solara-M62 @ 5.5psi
1gSE
Return to Forced Induction
