SolaraGuy.com • View topic - Dyno Numbers
Dyno Numbers
Dyno Numbers
Postby wagonsrule » Mon Jan 09, 2012 2:45 pm
Hi guys! I just dyno'd..
I know the Auto is really awful...
Got 172whp with the 4psi pulley on my 94 V6 S/C
So i got around what.. 20whp from the s/c?
94 Camry V6 Wagon SUPERCHARGED @ 5 psi!!!! One of a KIND! (6-7psi coming up)
SAFC
75 cu ft. of storage space :D
wagonsrule
Re: Dyno Numbers
Postby trd4life » Mon Jan 09, 2012 9:14 pm
Typically stock s/c 4psi auto setups dyno around 190-195whp and the manual trans are usually 220-225whp. What kind of dyno were you using?
Re: Dyno Numbers
Postby wagonsrule » Mon Jan 09, 2012 10:34 pm
It was a MAHA dyno. As far as ive seen its common that these dynos give u lower than normal whp readings. Im sure ive got a lot of restriction though.
SAFC
wagonsrule
Re: Dyno Numbers
Postby wagonsrule » Mon Jan 09, 2012 10:40 pm
Heres some pics
[img]http://i43.tinypic.com/6rn2wj.jpg[/i
[img]http://i40.tinypic.com/4e1s.jpg[/im
[img]http://i42.tinypic.com/dbskfr.jpg[/im
SAFC
wagonsrule
Re: Dyno Numbers
Postby wagonsrule » Tue Jan 10, 2012 9:34 am
Any opinion guys on the MAHA dyno? I've been seeing a lot of guys saying that MAHA dynos are hard to get good numbers on and that operator error is possible... i mean.. he said at one point that he was over 160kph... he certainly was not in 2nd.... Though im content with these numbers would i get close to 190 on a dynojet or some other dyno?
What kind of dyno do u guys use?
(same post as on Toyotanation)
SAFC
wagonsrule
Re: Dyno Numbers
Postby Brandoe91 » Thu Jan 19, 2012 10:37 pm
Numbers a little low but I'm sure it probably due the MAHA dyno. Like the work you are doing to the wagon. keep it up .
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Re: Dyno Numbers
Postby wagonsrule » Fri Jan 20, 2012 7:26 am
Thx! Im gonna go for 6 psi this spring ;) Gonna install new injectors, spark plugs and correct sized belt at the same time.
SAFC
wagonsrule
Re: Dyno Numbers
Postby Brandoe91 » Fri Jan 20, 2012 7:26 pm
Good luck! I am hoping to be a 6psi by then as well but 1st i need get my s/c install lol. Are you going to get your supra injectors cleaned or just throw them in?
Brandoe91
Re: Dyno Numbers
Postby wagonsrule » Fri Jan 20, 2012 9:41 pm
I still dont have injectors.. but im gonna be installing clean ones. I am not gonna risk going lean...
SAFC
wagonsrule
Re: Dyno Numbers
Postby 1gSE » Sat Jan 21, 2012 6:29 pm
wagonsrule wrote:I still dont have injectors.. but im gonna be installing clean ones. I am not gonna risk going lean...
Just some FYI, I found some n/a 2jz injectors on ebay for 45 bucks for the set. For that price you're pretty much guaranteed they're in bad shape (4 of them didn't even work). As soon as I got them, I shipped them to WitchHunter Performance and about $160 later all 6 were flowing what they should have been. One of these injectors from the stealership will cost more than that. Just trying to help a fellow boosted guy out 8)
Solara-M62 @ 5.5psi
1gSE
Re: Dyno Numbers
Postby Gregtrd » Sun Feb 05, 2012 1:51 pm
man those are some pissy #'s, u need to come see me, i've got the know how to get you 300whp, jetbtkng showed me how to get r done, ask anyone here im the man with the plan son...
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: Dyno Numbers
Postby trd4life » Mon Feb 06, 2012 9:53 am
Greg he is auto trans.
Return to Forced Induction
Users browsing this forum: No registered users and 84 guests
