SolaraGuy.com • View topic - Head Job ;D
Head Job ;D
Head Job ;D
Postby DSM_Lara » Tue May 29, 2012 4:58 pm
Getting ready for a Head Job... Leaking little oil from the rear valve cover :(
When I did change all my belts at 87k I forgot to do gaskets. Its always one thing after the other, hopefully after this I can finally do other things to this car.
Replacing all Valve Cover/Intake Gaskets, Spark Plugs, Oil Change, Trans Flush, and NST Crank Pulley.
Everything is mostly OEM from the dealership... I'm never going to put cheap ass parts in my car.
Please let me know if I'm missing any other parts (any other gaskets???), since I'm lifting mostly everything up... I know its a good opportunity to get a S/C, we will just have to see.
17176-62030 Air Surge Gasket
17177-20020 Intake Gasket Rear
17278-20020 Intake Gasket Front
11193-70010 Spark Plug Gaskets x6
11214-20010 Cylinder/Valve Cover Gasket Front
11213-20020 Cylinder/Valve Cover Gasket Rear
NST Crank Pulley anodized in Red
More stuff :D
25627-20010 EGR Gaskets
90480-18001 PCV Valve Grommet
90919-01194 Spark Plugs x6
19037-20011 Spark Wire/Cord Set
16261-20010 Water By-Pass Hose
16571-20020 Upper Radiator Hose
16572-20020 Lower Radiator Hose
DSM_Lara
Re: Head Job
Postby 1gSE » Tue May 29, 2012 5:07 pm
It'll be slightly more work, but since you're halfway there, I'd recommend replacing the coolant transfer hose under the lower manifold...and those gaskets
Solara-M62 @ 5.5psi
1gSE
Re: Head Job
Postby trd4life » Tue May 29, 2012 6:26 pm
pcv valve
Re: Head Job
Postby dinoxor » Wed May 30, 2012 1:14 am
wow weird just today I too bought my front valve cover gasket and spark plug seal
dinoxor
Re: Head Job
Postby alltrac92 » Wed May 30, 2012 6:14 pm
Change the PCV valve grommet 90480-18001 I would also do plugs and wires. What about the EGR and EGR pipe 25627-20010 gaskets?
alltrac92
Re: Head Job
Postby mig0s » Wed May 30, 2012 9:11 pm
I read 'hand job' and was disappointed when I clicked the thread :P
mig0s
Re: Head Job
Postby DSM_Lara » Thu May 31, 2012 5:58 am
:lol: :roll:
1gSE wrote:It'll be slightly more work, but since you're halfway there, I'd recommend replacing the coolant transfer hose under the lower manifold...and those gaskets
Yup, will be doing those too. :D
trd4life wrote:pcv valve
Gabe, I searched how to do the Tube Seals and your right they look like they are a PITA...
alltrac92 wrote:Change the PCV valve grommet 90480-18001 I would also do plugs and wires. What about the EGR and EGR pipe 25627-20010 gaskets?
PCV Valve, EGR Gasket picking it up tomorrow. Any recommendation of what type of plugs and wires I should get??? In other words probably the best performing products.
I'm hoping after this last maintenance my car should be running a lot smoother.
This Link will help me out a lot as a reference. ^_^
http://www.solaraguy.com/viewtopic.php?f=20&t=53130
DSM_Lara
Re: Head Job ;D
Postby alltrac92 » Thu May 31, 2012 5:14 pm
I went with OEM wires and plugs.
alltrac92
Re: Head Job
Postby Solarasian » Thu May 31, 2012 6:32 pm
mig0s wrote:I read 'hand job' and was disappointed when I clicked the thread :P
i think mig0s wanted a handjob from you LOL :Fade-color
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Kaminari Lip Kit(stand by)
Tokico hp Struts
Tein S Tech
Solarasian
Re: Head Job ;D
Postby DSM_Lara » Fri Jun 01, 2012 5:18 am
alltrac92 wrote:I went with OEM wires and plugs.
OEM it is, I guess $11 a piece per plugs won't hurt the pocket. :wink:
DSM_Lara
Re: Head Job ;D
Postby alltrac92 » Fri Jun 01, 2012 6:58 am
90919-01194 spark plug I paid $6.31 a piece.
19037-20011 cost me 33.96 for the wire set.
alltrac92
Re: Head Job ;D
Postby Brandoe91 » Fri Jun 01, 2012 10:48 am
Magnecor race wires , if you plan on doing performance upgrades. I personally have Ngk's and have no complaints .
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Re: Head Job ;D
Postby DSM_Lara » Sat Jun 02, 2012 4:57 am
alltrac92 wrote:90919-01194 spark plug I paid $6.31 a piece.
Hawaii is more expensive :evil:
More stuff :D
TRD Stuffs I had on the side...
TRD Struts Brand New in Box with Tein S-Tech from Greg a while back
TRD RSB
Below I have is my Christmas Tree with all the goodies. :wink:
DSM_Lara
Re: Head Job ;D
Postby dinoxor » Sat Jun 02, 2012 7:35 pm
Maybe you should post up a tutorial when you're done ;)
dinoxor
Re: Head Job ;D
Postby JavaJoe_2 » Sun Jun 03, 2012 9:25 am
Really like those TRD struts. I should have bought those instead of the JIC's.
Got Boost?? :sweet:
JavaJoe_2
Return to Forced Induction
