SolaraGuy.com • View topic - supercharger installed check engine light on
Postby cuj2002 » Tue Jul 17, 2012 9:03 pm
Hi,
Just finished up the supercharger install, engine light is on, power is good when driving, but idle is struggling, its low and bouncing between 400-500. Thought maybe the IAC valve was backwards, but we flipped it and then the engine light was flashing non-stop and the poor idle continued. Any ideas?
cuj2002
Re: supercharger installed check engine light on
Postby trd4life » Thu Jul 19, 2012 10:41 am
do you have the trd one way check valve installed on the iac line?
Postby cuj2002 » Thu Jul 19, 2012 10:59 am
We cut the line and inserted IAC valve as per the instructions, although the instructions never tell you to reconnect the line with the valve installed, we assumed that the line would be reconnected with the valve in, were we supposed to just leave it open with the valve hanging off the end?
cuj2002
Postby 1gSE » Thu Jul 19, 2012 11:05 am
Get some carb cleaner and check for vacuum leaks. When I installed mine there was an elbow on the bottom that wasn't shown on the diagram. Second time I pulled it off, the guy helping reinstall it put the throttle body gasket on sideways. Both problems made the idle rough.
Solara-M62 @ 5.5psi
1gSE
Postby cuj2002 » Fri Jul 20, 2012 1:57 pm
So ya i have a leak on the egr valve but unfortunately its because the bolts that came with my kit dont seem to thread properly into the supercharger
cuj2002
Postby Eye8Pussies » Sun Jul 22, 2012 12:36 am
use some rtv to help seal the egr leak
check the code that you're throwing as well- it'll probably be random lean codes, which point to a post-maf vacuum leak
Postby cuj2002 » Sun Jul 22, 2012 9:28 pm
I ended up getting a shop to re-thread the supercharger, everything's good now. Thanks for all for the advice.
cuj2002
Return to Forced Induction
Users browsing this forum: Google [Bot] and 98 guests
