by PlateLunch » Sun Aug 19, 2012 2:02 am
That's a mouthful! Does any one have an approximate length of the spacer used on the drivers side engine stud for the TRD S/C? Thanks.
PlateLunch
- Regular SolaraGuy Member
by trd4life » Sun Aug 19, 2012 2:40 pm
PM gregtrd he may be able to get you the specs
GLP Motorsports
is on FacebookToyota/Lexus Forced Induction Specialist
- SolaraGuy Semi-Pro Racer
by PlateLunch » Wed Aug 22, 2012 1:35 pm
bumpity bump bump bump...
PlateLunch
by PlateLunch » Thu Aug 23, 2012 4:08 pm
Thanks bro! Is there any way you could measure it or put something in the pic for scale? You da man!
PlateLunch
by alltrac92 » Thu Aug 23, 2012 6:44 pm
It's installed on my Camry so no go on the measurement. I would just thread two nuts on the threaded stud or you can stack some flat washers. If I had to guess I would say around 10mm.
alltrac92
- SolaraGuy Driver
by PlateLunch » Thu Aug 23, 2012 10:50 pm
Thanks again!
PlateLunch
Return to Forced Induction
