SolaraGuy.com • View topic - Bypass Stud on Trd Supercharger
Postby Brandoe91 » Fri Oct 12, 2012 8:21 am
I am having some trouble with the part of the supercharger that open and closes the bypass valve . It getting stuck during operation. Anyone else ever had a this problem before?
I removed the actuator and sprayed the stud with some wd40, left it over night but it is still gets stuck.
Any ideas???
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Re: Bypass Stud on Trd Supercharger
Postby 1gSE » Fri Oct 12, 2012 8:37 am
disconnect the EBC. Manual or auto?
Solara-M62 @ 5.5psi
1gSE
Postby Brandoe91 » Fri Oct 12, 2012 10:10 am
Manual. This is a parts car I recently bought , so I'm not sure if there is an ebc installed. I will check when I get home.
Brandoe91
Postby 1gSE » Fri Oct 12, 2012 11:22 am
oh ok. I never hooked up my ebc or the vacuum lines, so actuator doesn't work
Solara-M62 @ 5.5psi
1gSE
Postby Brandoe91 » Mon Oct 15, 2012 8:22 am
I guess the pb blaster and wd40 worked, it is working well now.
Brandoe91
Postby Brandoe91 » Sat May 14, 2016 1:51 pm
Brandoe91 wrote:I am having some trouble with the part of the supercharger that open and closes the bypass valve . It's getting stuck during operation. Anyone else ever had a this problem before?
I removed the actuator and sprayed the stud with some wd40, left it over night but it still gets stuck.
Any ideas???
Brandoe91
Return to Forced Induction
Users browsing this forum: No registered users and 89 guests
