SolaraGuy.com • View topic - EGR Question
EGR Question
EGR Question
Postby Bostonlara » Sat Dec 01, 2012 11:57 am
so i've been doing a lot of research on the forum and can't seem to find the answer i need.
a couple months ago i stumble across a supercharger on craigslist, it came with an auto EGR tube, problem is i have a manual. i've read that they aren't interchangeable but i've also read that they are bent differently only to clear the shifter cables coming from the firewall.
does anyone know if the tube will bolt up anyways, with either set-up?? then i can deal with the cables some other time?
thanks
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Re: EGR Question
Postby ASG14 » Sat Dec 01, 2012 2:23 pm
Change the EGR cooler to the Auto one and then the tube will work.
ASG14
Return to Forced Induction
Users browsing this forum: Google [Bot] and 98 guests
