SolaraGuy.com • View topic - My 3MZ supercharged 5speed Swap Thread
Re: My 3MZ supercharged 5speed Swap Thread
Postby PlateLunch » Sat Apr 06, 2013 6:30 pm
It takes care of the temp sensor code and it's pretty easy. When I get back home to my laptop I'll look for the link to the DIY I found, it was on a supra forum I believe, and I'll post it. You basically bend it into a U and stick it in the plug and wrap the shiz out of it with some electrical tape. The position sensor will still pull a code, that's something I've been working on for a minute but haven't figured out a fix for that one.
It's a 10k ohm 1/2 watt resistor. This link should cover it all http://www.envipcotech.com/randy/supra/egr/egr.htm. :D
PlateLunch
Postby Bostonlara » Fri Apr 12, 2013 11:21 am
Car should be out of the garage this weekend. I was hoping to finish last week but I had much crap to do with school and just needing a weekend for myself. If everything goes smooth ill be doing some basic street tuning just so I can putt around then it'll get y pipe work done. Then I'll do some serious street tuning
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Postby spikeyjad » Mon Apr 22, 2013 3:53 pm
Bostonlara wrote:Car should be out of the garage this weekend. I was hoping to finish last week but I had much crap to do with school and just needing a weekend for myself. If everything goes smooth ill be doing some basic street tuning just so I can putt around then it'll get y pipe work done. Then I'll do some serious street tuning
where are you at with it now?
very nice build by the way, its even got me excited. ive got an '05 3MZ and id love to see the outcome and some of the specifics of your build.
Keep up the awesome work! :sweet:
'05 3MZ - Camry ksport coilovers - TRD RSB - injen SRI - muffler removed
spikeyjad
Postby Brandoe91 » Tue Apr 23, 2013 7:52 am
spikeyjad wrote:where are you at with it now?
According to the SG facebook page it is up and running.
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Postby Bostonlara » Tue Apr 23, 2013 9:17 am
Yes the car is running. I have a 8 am appointment Saturday to get the y pipe fixed and still need to put together headlights and bumper as well as wire up and install the rest of the meth kit
Ill make a list of parts needed to do this mod once I have more time to sit down
Bostonlara
Postby Smaay » Wed Apr 24, 2013 12:38 pm
so for your tuning you only plan on using the AFC NEO?
1990 Celica All-Trac 3S-GTE
1997 Celica GT 1MZ/3MZ hybrid
1997 Supra 2JZ-GTE
2001 Celica GT-S 2ZZ-GTE
1998 Dodge Ram Cummins Turbo Diesel
Thats alot of BOOST!!!!
Smaay
Postby Bostonlara » Wed Apr 24, 2013 9:55 pm
Smaay wrote:so for your tuning you only plan on using the AFC NEO?
Yup. Budget is tight right now. Looking for a new job at the moment. Neo is already hooked up. 8 am exhaust appointment Saturday and then some tuning just to get things safe u know. Don't think I'll have time to install the meth until after the exhaust shop
Bostonlara
Postby spikeyjad » Sat Apr 27, 2013 5:24 pm
I Don't have a Facebook lol. I'm excited to see more about it. I Have a ton of questions but I'll wait for the parts listing to come out to answer most of them.
spikeyjad
Postby SirThomas88 » Thu May 02, 2013 3:26 pm
Bostonlara wrote:Other mods I've already had done myself:
- Injen intake
- Custom exhaust from cat-back
- Lower Springs Teins up front, Eibachs rear for even drop
- Tokico shocks front, KYB rear
- TRD rear sway bar on track setting
- TRD short shifter w/ TWM 400gram shift knob
- EBC Red stuff pads all round
- Slotted & drilled rotors
-NRG oil catch can
-Camaro Knock sensors
So the plan at the moment is this
-full 3MZ swap
-TRD Supercharger @ 5.5psi
-Snow Performance methanol injection with MAF boost controller @ 625ml nozzle
-305cc injectors
-NST Light Weight crank pulley
-Redesign my y-pipe (Lou's custom must have been drunk when they fab'd it)
-electronic exhaust cut-out
-Cold air extension
-Jim's Fuel Mod
-walboro 255 fuel pump
-170 degree thermostat
-colder spark plugs
Wow, your build sounds a lot like mine at 5.5lbs of boost, except for the 3MZ block and exhaust cut-out. Is Gabe helping you with this?
Looks awesome I'm impressed with your choice of mods. But I am biased because that's what I did.
I haven't read all the other posts in this thread yet, but a few suggestions:
Make sure to add an SAFC2 in there or other device for tuning and also invest in a good Wideband AFR gauge. I have a fantastic AEM UEGO Wideband for sale if you want. Also, talk to Greg, you might be able to get away w/o bigger injectors since you're adding methanol. Make sure your methanol kit is hooked up well and that you never run dry. Might want to consider the Snow Performance Safe Injection system.
SirThomas88
Postby SirThomas88 » Thu May 02, 2013 3:38 pm
Ok yea wow I am late coming into this thread with my last post haha. Sounds great dude can't wait to see your dyno results.
SirThomas88
Postby Bostonlara » Sat May 04, 2013 3:55 pm
SirThomas88 wrote:Ok yea wow I am late coming into this thread with my last post haha. Sounds great dude can't wait to see your dyno results.
lol thanks man. ya gabe has helped me out with this build for parts and info! the build has taken ALOT longer than expected, more so because of my limited time to work on it and after i discovered i shattered 5 out of 6 piston ring lands on 5 of my pistons :drinking:
ya i got the same wideband too! and i'm pretty sure my supra injectors are out of your car actually. saw it in person when i drove up there over the winter. engine was very impressive even on the engine stand! my meth isn't hooked up yet because i had a appointment at Lou's Custom for a custom y pipe. its completely free flowing and actually makes the car sound super mean crawling around town.
im installing my rear EBC red stuff pads this weekend and hopefully doing the meth set up sunday or monday. pump and reservoir are bolted in but controller and nozzle need to be put it.
The car has so much more torque in second and third gear with 3MZ set-up. haven't floored it yet and going boosted to 4psi once. otherwise im running a rich tune for the time being and will wait to floor it and experience the full 5.5psi pulley!
Bostonlara
Postby Bostonlara » Mon May 06, 2013 8:34 pm
Okay, so since I've been driving the car and done some tuning I've noticed a few problems. Car the will not boost past 3/3.5 psi no matter what. I previously stated a saw 4 psi which did happen. Car feels good in closed loop but once it's goes open loop it starts to bog down a bit and won't pull hard at all. I need to check the vacuum lines out again. I also threw 6!!!! Yes 6 codes. P0100, 110, 120, 135, and p1410, p1411. Cleared the codes drove, hit open loop and only p0135 came back right away. Didnt drive long enough after that to see if any others came back. The codes a wacky though, throttle position sensor, Maf sensor ( could be covered in oil from previous engine), and a lean coolant sensor code ( this one made me do a double take). So once I get more free time ill have to figure these out, and it's finals week.
One thought on why I'm not boosting fully could be the 3MZ heads. Just a thought but maybe they can't hold the boost like the 1MZ heads because on the VVTI being disabled? Idk just a thought
Bostonlara
Postby trd4life » Tue May 07, 2013 7:01 am
what knock sensors are you running? Have you checked your bypass valve to see if there's any rips in the diaphragm?
Postby Bostonlara » Tue May 07, 2013 11:49 am
trd4life wrote:what knock sensors are you running? Have you checked your bypass valve to see if there's any rips in the diaphragm?
Ill have to check diaphragm, I'm running GM knock sensors right now. I'm thinking vac line but it seems like a lot of boost pressure just isn't there. Foot to the floor and it consistently makes 3psi everytime. I made more with the 3.4" pulley that came with the charger and that maxed at 5 sometimes 6psi. I hope it's not the 3MZ heads
Bostonlara
Postby Gregtrd » Tue May 07, 2013 12:22 pm
If you want to get rid of those 3mz heads let me know.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Return to Forced Induction
