SolaraGuy.com • View topic - Bypass actuator
Bypass actuator
Bypass actuator
Postby lilm » Tue May 14, 2013 12:42 pm
Alright gents been awhile since I've had a problem. Turns out while fiddling with some vacuum hoses i broke the nipple of the damn bypass actuator. I have attempted to epoxy the damn nipple on and when connecting it back up it flippin broke again. Any one have a replacement link? I remember everyone talking about taking the actuator off and actually boosting all the time is there anyone that has had long term experience with this or should i stick with getting a working actuator?
lilm
Re: Bypass actuator
Postby Bostonlara » Tue May 14, 2013 1:01 pm
lilm wrote:Alright gents been awhile since I've had a problem. Turns out while fiddling with some vacuum hoses i broke the nipple of the damn bypass actuator. I have attempted to epoxy the damn nipple on and when connecting it back up it flippin broke again. Any one have a replacement link? I remember everyone talking about taking the actuator off and actually boosting all the time is there anyone that has had long term experience with this or should i stick with getting a working actuator?
I remember someone posted a link awhile back but it was for a 3800 series Buick. Only difference is the rod is half the length so u need to extend it. Ill try and find the link
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Re: Bypass actuator
Postby 1gSE » Wed May 15, 2013 6:12 am
Mines never been hooked up since the install and I have no problems at all. You won't be "boosting all the time."
Solara-M62 @ 5.5psi
1gSE
Return to Forced Induction
