SolaraGuy.com • View topic - Turbo Coupe Build
Turbo Coupe Build
Re: Turbo Coupe Build
Postby 2wickedtoyz » Mon Nov 17, 2014 3:38 pm
Update
Car is still running strong and since the build I've driven 5k hard miles without an issue. The engine response is amazing and I'm surprising the hell out of people.
2wickedtoyz
Postby TadS » Thu Nov 20, 2014 8:21 pm
Did you pull the exhaust to drive the turbine from just the front header, or after the Y? I'm having trouble seeing where you tapped into the exhaust flow.
TadS
Postby 2wickedtoyz » Tue Nov 25, 2014 4:47 pm
i'm running a ypipe to use both banks. it comes up to where the turbo is
2wickedtoyz
Return to Forced Induction
