SolaraGuy.com • View topic - boost gauge install
boost gauge install
boost gauge install
Postby thakidd » Fri Apr 30, 2004 2:08 pm
what fitting would i need and how do i tap into the top of the s/c...
i already have the boost gauge...1 other thing im curious bout would i run lean with stock boost and the cai.
thanxxx
thakidd
Postby Astro » Fri Apr 30, 2004 2:58 pm
try doing a SEARCH, this topic has been discussed many times. :wink:
Postby beavis820 » Sat May 01, 2004 12:06 am
I have the same problem with my camry... the search button takes you on a 3 hour tour and you never find what your looking for. someone out there please say what fitting it is without sending us to the search button.
beavis820
Postby JoeB » Sat May 01, 2004 5:22 am
Rather than tell you the answer, I'll point you to a good thread because the answer isn't simple. There is a place right underneath the strut bar to screw the fitting in. There is a plug there currently. The problem is, it is too close to the strut bar. You'll see some people cut their strut bar to solve this issue. What I did was have a fitting tapped into the side of the sc housing because the clearance was so tight on mine that even with washers, it was hitting in reverse and making a terrible noise. Try this thread: http://www.zer0.info/solaraguy/viewtopic.php?t=3948&highlight=boost+fitting . I think with the stock 4psi boost, adding the CAI should not make your car run lean. Although, anytime you change your air flow, you might change the volumetric effficiency of the engine. -JoeB
JoeB
Return to Forced Induction
