Gen 1 Solara Aftermarket Brakes / Drivetrain List
*Brakes / Brake Pads*
Brembo Big Brake Upgrade
#1B4.699R
Goodridge Stainless Steel Brake Lines
#21064
TRD Brake Pads
(F) #00602-04491-028
(R) #00602-04492-014
*Clutch / Flywheel / Limited Slip Differential*
Fidanza Lightened Flywheel 6cyl
9lbs.
#130881
SPEC Clutch for V6
Stage I - High clamp pressure plate with organic disc 375 ft-lb
#ST821
Stage II - High clamp pressure plate with kevlar disc 420 ft-lb
#ST822
Stage III - High-clamp pressure plate with race disk 492 ft-lb
#ST823
Stage IV - High-clamp pressure plate with 6-pad rigid disk
(quick engagement; for race cars) 492 ft-lb
#ST824-6
Stage IV - High-clamp pressure plate with 3-pad rigid disk
#ST824-3
ACT Clutch for V6
Heavy Duty Pressure Plate w/ Modified Street Disc Kit 341 ft-lb
#TY3-HDMM
Heavy Duty Pressure Plate w/ 4 Pad Race Disc Kit
(quick engagement; for race cars) 436 ft-lb
#TY3-HDR4
Heavy Duty Pressure Plate w/ 6 Pad Race Disc Kit
#TY3-HDR6
Quaife Limited Slip Differential
#94.309.160
Kaaz Limited Slip Differential
#DAT-2010
#1B4.699R
#21064
TRD Brake Pads
9lbs.
#130881
SPEC Clutch for V6
#ST821
#ST822
#ST823
#ST824-6
#ST824-3
ACT Clutch for V6
#TY3-HDMM
#TY3-HDR4
#TY3-HDR6
#94.309.160
#DAT-2010
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
 shidosha01
- Mod Alumni
