SolaraGuy.com • View topic - replacement struts and shocks??
Postby cablemn » Tue Jul 20, 2004 4:56 pm
on long sweeping turns, if i hit a bump the rear skips out a little. i'm not used to that at all coming from an altima 3.5 se. do any of you guys with the se sport have that problem? i'm trying to decide if i should change the struts and shocks. any advice in this matter is greatly appreciated.
cablemn
Postby vuuuuu » Tue Jul 20, 2004 7:32 pm
It happens to me too, but also that happened in my prelude because I got stiffer shocks and springs and that caused the car to kind of jump a little when hitting bumps because they were shortstroke shocks. I'm guessing because the suspension is somewhat "stiff" and it causes that to happen. I don't see any problem.
2004 SLE V6 Lunar Mist Solara
vuuuuu
