SolaraGuy.com • View topic - BMW Lighting Look
BMW Lighting Look
BMW Lighting Look
Postby Willy7o2 » Thu Sep 30, 2004 3:54 pm
I was driving home one night after work. I saw in the rear view a pair of really nice purple-ish lights closing in. Stopped beside me at the light and saw it was an M3. I want to know if its possible for my Solara to have that same type of bulbs. Where can I get them?
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby Mole » Thu Sep 30, 2004 4:42 pm
they are HID.
you can't achieve that look unless you have projectors that move(for balance) and HID aftermarket lighting.
Postby jsie » Thu Sep 30, 2004 4:47 pm
And, I do believe after a few minutes as the HID reach the normal operating temperature; the color would turn from purple-ish to bright white.
2004 Solara SE Sport
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Postby DocJohn » Thu Sep 30, 2004 5:42 pm
jsie wrote:And, I do believe after a few minutes as the HID reach the normal operating temperature; the color would turn from purple-ish to bright white.
The BMW HID's will be bright white when up to temp, but still look purpleish when viewed off-angle.
If you want lights like this and you want to "do it right" you'll need to buy an HID set-up. If you want to "do it cheap" you can get some of the aftermarket halogen bulbs with higher color temps like PIAA's, Hoen's, Nokya's, etc. Check out the color of my halogen lights on my website.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby krawzyazn » Thu Sep 30, 2004 7:05 pm
if you want the purple look i have the 10k hid kits in the forsale section
Postby ICrazyChrisI » Fri Oct 01, 2004 12:18 am
You actually dont even need HID for that look. Your Solara's projectors have the same effect, but not as much seeing that the M3 has wayy stiffer suspension. Also to add, your car doesn't need the self leveling thing either.
ICrazyChrisI
