SolaraGuy.com • View topic - Need help.... FSTB & RSB Install
Postby Willy7o2 » Thu Oct 07, 2004 12:39 pm
I just got my FSTB & RSB in this morning. I won't have time to install it til the weekend, so I want to post this to get some tips. I've been reading about so&so lbs ft. on the nuts? I don't understand. Also, Is there any special grease, tools, etc. I should have?
'04 Solara V6 SLE
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby DocJohn » Thu Oct 07, 2004 5:51 pm
The silicone grease for the RSB bushings comes with it.
To install these you should have a torque wrench to do the job right. If you overtighten the RSB bolts you can deform brackets & bushings, strip threads, etc.
You'll also need the correct size metric sockets for the nuts & bolts. The FSTB uses a 14mm socket and the nuts are torqued to 59 ft-lbs. I forget the size and specs for the RSB, but they're in the instructions. Also see this posting for more info on the RSB install:
http://www.zer0.info/solaraguy/viewtopic.php?t=11716
If you need more info, let us know and I'm sure someone here can help.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby Willy7o2 » Thu Oct 07, 2004 8:54 pm
DocJohn wrote:The FSTB uses a 14mm socket and the nuts are torqued to 59 ft-lbs. I forget the size and specs for the RSB, but they're in the instructions. Also see this posting for more info on the RSB install:
How do you tell how many ft-lbs you're putting on the nut/bolt? I'm stupid
2004 Solara V6 SLE
Front GFX Lips
Willy7o2
Postby DocJohn » Fri Oct 08, 2004 6:02 am
That's what the torque wrench is used for. You set the torque wrench to the specified torque you need for the nut or bolt.
Take look at this for detailed info on how to use a torque wrench:
http://www.goodson.com/instr/TQR-200.pdf
You may want to have a friend, etc. who has a little more mechanical/auto experience give you a hand with this installation.
DocJohn
Thanks DocJohn...
Postby mmcdonald » Sat Oct 09, 2004 9:05 am
Here are the specs all around:
Front Strut Tower Brace:
4 - 14mm nuts, 59ft/lbs each
Rear Sway Bar:
6 - 12mm bolts, 14ft/lbs each
2 - 14mm nuts, 29ft/lbs each
Torque wrenches are different. Some you just look at the guage, others you set them and when you feel them "snap", you have hit your preset torque rating. Mine snaps.
The top driver side rear sway bar bolt may not be accessible with your torque wrench, so do it last after you get a feel for 14ft/lbs.
Use ALL the grease that comes with the rear sway bar.
Be SURE to do these installs on a flat garage floor!!! Absolutely essential. No jacking should be needed.
The Front Strut Brace is a one man job, but the Rear Sway Bar is best done as a two man job.
Good luck and post some pics.
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby Willy7o2 » Sat Oct 09, 2004 4:50 pm
Thanx mmcdonald. That's the exact info I'm looking for.... now, how do you post pics?
2004 Solara V6 SLE
Front GFX Lips
Willy7o2
Posting Pics
Postby mmcdonald » Sun Oct 10, 2004 5:26 pm
Good question...
The first thing you need to do is find a site that will host your pics. I have my own web site.
Then when you make a post, like this, you will see a bunch of formatting buttons at the top of the page beneath the subject line. The second to the last one says "Img"
Format your reply and then find a spot where you want your pic. I suggest after a carriage return. Then you click the Img button, and it puts in a tag like this... "[img]"%20Then%20insert%20the%20link%20to%20your%20pic,%20like%20this...%20"http://www.mywebsite.com/images/carpic.jpg"%20Then%20click%20the%20Img%20button%20again%20and%20it%20puts%20in%20a%20closing%20tag,%20like%20this...%20"[/img]"
It's all ancient HTML.
XM Tuner DIY
mmcdonald
Postby Willy7o2 » Tue Oct 12, 2004 8:27 pm
OK, got Sway bar yesterday. FSTB will be here next week due to lack of stock. So, woke up this morning planning to put it on after-work. After 30 mins, I called in late and got started on the installation. Took over 90min, but finally got it installed. The steps for the installation is easy, but putting the bush back on with the new sway bar was a b1tch. about an hour was just working on putting the bush back on the driver's side. After all the hard work, 2 hours off from work, and 6 black hand prints on rear bumper from going under the car and out; well worth it. Now, I can take the turns and not worry about the body-roll. Now, my tires are squeeling.
Thanx for all you guy's help. :lol:
2004 Solara V6 SLE
Front GFX Lips
Willy7o2
Dang
Postby mmcdonald » Wed Oct 13, 2004 4:25 am
Sorry, I forgot to mention about the hand prints on the bumper. It is so conveniently placed for getting out from under the car. That grease is a b1tch to get off, too. :D
XM Tuner DIY
mmcdonald
Postby Astro » Wed Oct 13, 2004 9:03 am
AZNBoYie02 wrote:Thanx mmcdonald. That's the exact info I'm looking for.... now, how do you post pics?
Most of us have pics at cardomain.com. Then, just link your pics like mentioned above.
