SolaraGuy.com • View topic - STOPTECH Big Brake Kit now available
Postby DocJohn » Mon Oct 18, 2004 6:58 am
STOPTECH Big Brake Kit http://www.stoptech.com
Solara 2004+, 332mm x 32mm slotted or drilled rotors, 4 piston calipers, stainless steel brake lines, Axxis Ultimate brake pads, red or black calipers. Add $100 per pair for drilled rotors.
$1895.00 - Item No. 83-865-4600
DocJohn
Postby junest » Mon Oct 18, 2004 9:49 am
:o Add another $100 if you want it drilled.
2004 Solara SLE V6 Convertible
Webpage
junest
super solara girl
super solara girl
Postby Willy7o2 » Mon Oct 18, 2004 10:06 am
is that a good/normal pricing for brakes? I need new ones, cuz mine are starting to make high squeeling noise when braking sometimes. I'm thinking Toyotas brakes aren't that great. My mom's Sienna and my dad's tacoma does the same thing after 1 year of driving. Less than 15k mi. I dunno.... what is best to get for good price?
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby junest » Mon Oct 18, 2004 10:49 am
AZNBoYie02 wrote:is that a good/normal pricing for brakes? I need new ones, cuz mine are starting to make high squeeling noise when braking sometimes. I'm thinking Toyotas brakes aren't that great. My mom's Sienna and my dad's tacoma does the same thing after 1 year of driving. Less than 15k mi. I dunno.... what is best to get for good price?
That is normal price for a BIG BRAKE kit. You can replace yours with a non-Toyota brand brakes and give that a try. I know what you mean about Toyota brakes, my Camry did the same thing.
Webpage
junest
super solara girl
super solara girl
Postby Mole » Mon Oct 18, 2004 1:23 pm
$2k is around right. but if you ask me its on the cheaper side for a BB kit.
if this were avail for gen 1, i would get it in a heartbeat.
Hey
Postby mmcdonald » Thu Oct 21, 2004 4:40 am
Will those fit under the stock 17" rims? Or do they require 18"+?
What is the increase in diameter from stock?
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby i20solara02i » Thu Oct 21, 2004 5:05 am
well i try getting a groupbuy from them before. and they said no. and i was also trying to figure if the gen 2 were the same as the gen 1 but they didn't want to check it out. :evil: o well
i20solara02i
Postby nsx1164 » Sat Oct 23, 2004 6:45 am
Looks like a reasonable setup for a FRONT BBK upgrade.
- Do they have a matching rotor fitment for the rear, using the stock caliper?
- Is front/rear brake bias an issue with the front-only fitment, or are these OK ??
For those who have done BBKs, or consider the OE braking inadequate, am curious to hearing your comments.
I have an AP Racing BBK on my track car, mainly for reduced R&R (less replacement of rotors/pads), reduced fade, etc... I find that to fully benefit from "more braking" you really need track (R-compound) tires; with street tires I often find myself over-braking the tires (brake power >> street tire grip).
More $$ for cross-drilled, which are really more a "bling" upgrade. Slotted rotors typically perform better over time (better thermal mass, less susceptible to cracking).
Of course BBKs just look cool :)
Downsides besides $$ are the potential for increased weight due to the bigger rotors, although most aftermarket BBK feature lighter-weight calipers and 2-piece (rotor/hat) setups.
nsx1164
Postby PXLpainter » Mon May 15, 2006 12:49 pm
Any info on that rear brake kit as well?
That's still about 1/2 the price of the Precision kits!
Postby chinaxb0y » Mon May 15, 2006 12:57 pm
richard i thought u said that the gen 2 were the same ? i talked to stoptech and they said the 97-01 camry is the same as the gen1/gen1.5.
chinaxb0y
Postby ---CAMRAZY--- » Mon May 15, 2006 1:13 pm
Gen 1 and 2 are not the same..
Postby Biggi_e » Mon May 15, 2006 1:16 pm
damn pretty pricey...i wish i had the money for it tho..i need new brakes pads =/[/img]
Postby WSkids97 » Mon May 15, 2006 8:50 pm
nsx1164 wrote:Looks like a reasonable setup for a FRONT BBK upgrade.
Out of curiousity NSX did you upgrade your master cylinder as well? Majority of the time from what I've noticed is that so many people upgrade their amount of brake pistons and loose braking distance due to insufficant preasure...
WSkids97
