SolaraGuy.com • View topic - Eibach Camber Alignment Kits
Postby TS04 » Sat Nov 06, 2004 12:18 am
Couldn't sleep so went looking for parts. Found this. Not sure if its necessary since some of you already lowered your cars without this.????
After the installation of either an Eibach Pro-Kit or Sportline spring set, a vehicle's alignment should always be checked. Once lowered, a wheel's camber may become increasingly negative, meaning the top of the tire is angled inward (toward the center of the vehicle). While some negative camber aids in improving traction and road adhesion, too much can result in peculiar handling and accelerated tire wear.
Eibach offers a complete range of alignment kits which offer a simple, affordable solution to adjust negative camber. These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications but they also allow the experienced chassis tuner to utilize the increased adjustment range to dial-in a performance alignment that uses negative camber to maximize a chassis' potential. Turn-in becomes more precise and handling increasingly crisp and predictable. High-speed stability is also enhanced making an alignment kit from Eibach almost a necessity for the serious performance tuner.
(Just Trying to Help out the Market)
04 Solara SE Sport Coupe Black
35% Tint Sides, 20% Back
Clear Corners
Blue Illuminated Entry
Mike T' Black Combo Grills
TS04
Postby junest » Sat Nov 06, 2004 1:50 am
Nice find. We could've used that when Milt lowered my ride. I've already done the allignment.
2004 Solara SLE V6 Convertible
Webpage
junest
super solara girl
super solara girl
Postby got sport » Sat Nov 06, 2004 10:23 am
I have and use lifetime wheel alignment. I take it in every 5K miles.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby TS04 » Sat Nov 06, 2004 3:27 pm
Glad to hear. I'm trying to help out the rare market a little bit. Now I know I can get a lifetime alignment. WHOO HOO.
Clear Corners
TS04
Postby got sport » Sat Nov 06, 2004 3:41 pm
All we need now is that supercharger.
got sport
