SolaraGuy.com • View topic - Hoen Xenonmatch plus H11 bulbs
Postby sportscarguy » Mon Dec 06, 2004 3:17 pm
has anyone tried Hoen Xenonmatch plus bulbs?
since they are rated at 70Watts, will these melt the standard wires/connectors in the car? can someone check?
anyone got pics?
sportscarguy
Re: Hoen Xenonmatch plus H11 bulbs
Postby DocJohn » Tue Dec 07, 2004 9:05 am
sportscarguy wrote:has anyone tried Hoen Xenonmatch plus bulbs?
anyone got pics?
I haven't tried the Hoen Xenonmatch plus bulbs yet, but I've been running Nokya H11's that pull nearly 75 measured watts since August with no problems at all. See my bulb test page for specific information at: http://www.angelfire.com/ky3/gabby/bulb_test.htm
If you are still concerned you can always use a pair of Hoen's heavy duty connectors. http://www.hoen-usa.com/connector.htm
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby mikei » Tue Dec 07, 2004 5:29 pm
Here is a reply from hoen about a lighting upgrade for Gen 2
Thats correct Mike, we suggest the H11 xenonmatch Titanium which does not require connector upgrades nor will it overtax the system. 80w is fine with the projectors but we recommend a connector upgrade.
The Vi is well suited for the projectors however it will not be shipping for a month. It is 6% less bright as our xenonmatch line so if your looking for the most powerful the xenonmatch line is the brightest.
Thanks
Andreas
----- Original Message -----
To: info@hoen-usa.com
Sent: Thursday, November 04, 2004 3:50 PM
Subject: 2005 Toyota Camry Solara SLE V6 Convertible- Suggestions for lighting upgrade?
Hello
My name is Michael and I am interested with your suggestions in upgrading my stock lighting, especially the low beams.
I believe they are H11 and they employ the new projector system.
I am asking you directly because of my concerns with overloading the wiring and/or projector housing with excessive heat.
Your new system coming at the end of november (xenonmatch Vi 7) looks interesting. How much of an improvement over the
toyota low beams will be provided by these new bulbs?
Thank You
2005 Solara SLE V6 Convertible-Silver
VSC/TRAC/NAV/XM Sat/Mudflaps/Clear license plate covers/Bug deflector/Glass breakage sensor/SS Door Sills/Eclipse backup camera
Japan voice-mic/Everything TRD
mikei
