SolaraGuy.com • View topic - Tein SS Coilover avail for Gen 2 (news?)
Postby Jackass-Jeff » Fri Feb 11, 2005 12:24 pm
1GR-FE ftw!
Jackass-Jeff
Postby Blazed04 » Fri Feb 11, 2005 1:16 pm
I knew they were coming...but i guess we still dont know when. Thats gonna be a nice drop though, 3/4 in up to 3inches.
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby TS04 » Fri Feb 11, 2005 2:25 pm
I don't know how much coilovers usually go for. Any educated guesses????
04 Solara SE Sport Coupe Black
35% Tint Sides, 20% Back
Clear Corners
Blue Illuminated Entry
Mike T' Black Combo Grills
TS04
Postby Astro » Fri Feb 11, 2005 2:45 pm
TS04 wrote:I don't know how much coilovers usually go for. Any educated guesses????
Well, I now you can get gen1's now for around $1200. I would think they'd be a little higher, probably around $1600?
Postby Jackass-Jeff » Fri Feb 11, 2005 3:46 pm
Tein SS are generally around 1400
1GR-FE ftw!
Jackass-Jeff
Postby got sport » Fri Feb 11, 2005 5:34 pm
Sweet!!! About time!
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby sorkang724 » Fri Feb 11, 2005 8:51 pm
wut's the difference between the two links ???... :o
sorkang724
Postby Parke10 » Fri Feb 11, 2005 9:13 pm
the info is different cuz its the 4cyl and V6
Parke10
Postby TS04 » Sat Feb 12, 2005 10:01 am
Sorry for the ignorance. Coilovers replace the whole suspension right?? so no need to buy new struts???
Clear Corners
TS04
Postby Jackass-Jeff » Sat Feb 12, 2005 1:11 pm
TS04 wrote:Sorry for the ignorance. Coilovers replace the whole suspension right?? so no need to buy new struts???
Generally a coilover has a stiffer spring rate than most springs out there, the height is adjustable and the dampening/rebound force can be adjusted...
So you can pretty much pick the height you want to be lowered to, how hard the struts are (tunable!) and handle REALLY well!
The package includes:
Adjustable Dampers (aka struts), Springs, wrenches to adjust the ride height, adjustment "nut" to adjust the force of the dampers but no mounts... you have to use the stock ones =[
I almost forgot, the coilovers come with 2 sheets of STICKERS!!
1GR-FE ftw!
Jackass-Jeff
Postby TS04 » Sat Feb 12, 2005 1:37 pm
Thanks for the clarification guys. Learned something new today.
Jackass-Jeff: That's F*in OUTRAGEOUS. Haha. ICan't wait til they come out.
Clear Corners
TS04
Postby trdkamuri51o » Sat Feb 12, 2005 10:54 pm
yo jeff temp me to keep on spending money foo!!!
trdkamuri51o
Postby sorkang724 » Sun Feb 13, 2005 1:03 pm
how do you adjust the height ????....is it something you can do by yourself at home or do you need to take it in a shop everytime ...and how do you change the height level ???...is it a screw or something ?
sorkang724
Postby Jackass-Jeff » Sun Feb 13, 2005 10:20 pm
you unlock the bottom "spring seat" and turn it UP or DOWN ... the car needs to be lifted to do it
1GR-FE ftw!
Jackass-Jeff
