SolaraGuy.com • View topic - Weapon R intake for the gen 2 !!!!!!!!!!!!
Postby sorkang724 » Wed Feb 16, 2005 11:13 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33659
has anyone seen this or anyone ever used it ???..how are they ...please post some comments
sorkang724
Postby thealkimo » Wed Feb 16, 2005 12:24 pm
it says 02-04 but i don't think they mean gen 2 solara
thealkimo
Postby sorkang724 » Wed Feb 16, 2005 3:10 pm
i just checked the application chart on weapon-r.com and they do have one for the 02-04 camry...does that mean is gonna fit the solara toO ?
sorkang724
Postby Blazed04 » Wed Feb 16, 2005 7:07 pm
Well for the V6, no. The camry and solara dont share the same V6 engine. But as for the I4..i guess so??:-?
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby slingshot » Wed Feb 16, 2005 7:59 pm
The Camry has the same 3.3 liter V6 as the Solara.
slingshot
Postby Blazed04 » Wed Feb 16, 2005 8:50 pm
...well yeah the SE v6 camry. Forgot about that one.
2001 GSXR 750
Blazed04
Postby sorkang724 » Wed Feb 16, 2005 11:49 pm
so does that mean that'll work for our car ?
sorkang724
Postby TS04 » Thu Feb 17, 2005 7:26 am
Blazed04 wrote:Well for the V6, no. The camry and solara dont share the same V6 engine. But as for the I4..i guess so??:-?
Is it another SRI????
04 Solara SE Sport Coupe Black
35% Tint Sides, 20% Back
Clear Corners
Blue Illuminated Entry
Mike T' Black Combo Grills
TS04
Postby got sport » Thu Feb 17, 2005 9:05 pm
Looks tempting...
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby Astro » Fri Feb 18, 2005 1:19 am
TS04 wrote:Is it another SRI????
I'm pretty sure it is.
After checking out weapon-r.com, I noticed this:
Have your custom intake made today.
AIR FILTER / COUPLERS / HOSES ALL SOLD SEPERATELY.
Made of 6061 Aluminum
Mendrel Bent
Hand Tig Welded
Made to your spec's
Charges:
Per Bend: $40
Per 12" Straight Section: $40
Per Nipple:
4mm Nipple Welded: Add $20
8mm Nipple Welded: Add $22
10mm Nipple Welded: Add $23
15mm Nipple Welded: Add $25
1" Nipple Welded: Add $30
Per Aluminum Air Flow Sensor:
Subaru Air Flow Sensor Welded: Add $40 ( SENSOR 2 )
Nissan Air Flow Sensor Welded: Add $40 ( SENSOR 3 )
Ford Air Flow Sensor Welded: Add $40 ( SENSOR 3 )
Toyota Square Air Flow Sensor Welded: Add $40 ( SENSOR 1 )
Toyota Triangle Air Flow Sensor Welded: Add $40 ( SENSOR 2 )
Polishing:
Per 24": Add $50
Per 48": Add $60
Convert custom intake to Secret Weapon Configuration:
Add: $90
Please include 6 good pictures ( Multiangle ) with an measuring tape next to the OEM intake pipe.
Drawing of your desired configuration.
Size and location of nipple(s).
Type and Location of Sensor. ( If applicable )
That would add up, but if you got the money it can be done.
