SolaraGuy.com • View topic - After Market TIRES on stock 17" wheels
Postby mmcdonald » Mon Apr 04, 2005 5:24 am
Okay, no ribbing. Honestly, I need to retain the stock 17" rims on the 04 Solara. I want to get a new set of tires (after 30K on the Turanza things) but I would like to bump them up a bit.
The best tires I have found in the stock 215/55 17 are the Avon Tech M550 A/S (yes, that's all season) that are WR rated for $110 each on TireRack.
What about 225 55 or 50? Has anyone done this? Any handling issues?
Please don't suggest 18" or bigger rims, cause I can't get away with that. The boss wouldn't let me. :D
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
so then...
Postby mmcdonald » Tue Apr 05, 2005 5:31 am
So the 225/55 then? I could do that, although that would introduce some sidewall flexing.
At the current 215/55 versus 225/55 that is a 118.25mm versus 123.75mm sidewall, or a 5.5mm increase in height of the sidewall, and an 11mm increase in overall height of the tire (about a half inch.) If I did a 225/50, then that is a 112.5mm sidewall, and a shrinkage of 5.75mm, or 11.5mm overall. So that is a half inch smaller. Hmmm...
You know, I would get performance gains (torque and cornering) going with the 50's, but better mileage and a better look with the 55's. Although the rims might look smaller with the 55's.
Has anyone done either of these? If so, impressions? pics?
XM Tuner DIY
mmcdonald
Postby Whatever » Tue Apr 05, 2005 2:45 pm
yeah 225/ 45 /17 would fit and you should do that :lol:
try ebay they have a lot of cheap tires for 17" 8)
Whatever
well
Postby mmcdonald » Wed Apr 06, 2005 4:45 am
I am not lowered... yet (if I can get away with it) so I think the 45's would be a little too radical for me.
Does anyone have pics of 225/55? I have seen a 225/50, but the car was too dirty to get a good look.
Thanks all.
XM Tuner DIY
mmcdonald
Users browsing this forum: Majestic-12 [Bot] and 34 guests
