SolaraGuy.com • View topic - Sound Dampening/Dynamat
Postby dvdchris45 » Fri Apr 08, 2005 10:44 am
Anyone know where I can find some good quality but not-so-expensive Dynamat? So far I found one for $90 but thats 200 sq ft. I dont need that much! Any suggestions?
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby theprodigy79 » Tue May 17, 2005 9:01 am
I personally recommend Dynamat Xtreme Door Kits. Each box contains four 12" x 36" sheets. I've seen them on-line for as low as $50... around $70 from reputable sources that I am familiar with. 3 boxes covered my doors and trunk, perfect amount of material to do what I needed. Xtreme is the highest grade of Dynamat; you can find the lower grades for even less, however I'd say it's a great investment.
theprodigy79
Postby cam2Xrunner » Wed May 18, 2005 2:37 am
Dynamat Extreme is VERY expesive and there is the same if not better stuff out there for much less.
By those numbers
12 Sq ft of Dynamat Extreme is 50 bucks
For 65 dollars you can get roughly 50 Sq ft of Edead V1.se which is 70 mils thick.
http://www.edesignaudio.com/forum_discount.php
62.5 Sq ft of Raammat60 sells for 89 plus shipping(ask for the forum discount). Raammat is Butyl Based and not asphalt like reg dynamat and others. Sticks very good and is very easy to work with. I've had lot's of good experience with this product.
www.raamaudio.com
There's also a new product out from www.secondskinaudio.com Called Hazmat that is 65 mils thick with a 2 mil mylar Film. This is Butyl Rubber as opposed to Asphalt based as well. The advantage to this product is that it wieghs less than reg aluminized backed matting. To some that is very important for reducing overall weight.
http://www.secondskinaudio.com/products ... roductid=4
Pricing and more info there.
cam2Xrunner
