SolaraGuy.com • View topic - Clear Corners DONE !!! 1st in CA !
Postby sorkang724 » Thu May 12, 2005 1:29 pm
I'm finally done with my clear corners. I must say it took alot of work , but it was well worth it, click links below to check them out ! Took about 2 hours or so, because my friend has previous experience with it, so all we had to do was take out the parts, bake the headlight, then remove reflector and put everything back. if you need anymore info, let me know.
http://i5.photobucket.com/albums/y160/s ... G_1674.jpg
http://i5.photobucket.com/albums/y160/s ... G_1677.jpg
http://i5.photobucket.com/albums/y160/s ... G_1678.jpg
http://i5.photobucket.com/albums/y160/s ... G_1684.jpg
http://i5.photobucket.com/albums/y160/s ... G_1682.jpg
http://i5.photobucket.com/albums/y160/s ... G_1683.jpg
sorkang724
Postby Jai_Jai_Binks » Thu May 12, 2005 1:53 pm
COngrats on the first to attempt!
Postby got sport » Thu May 12, 2005 2:00 pm
Nice work...now I'm tempted to do it too...but that first picture scares me.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby ndoyank » Thu May 12, 2005 2:26 pm
You must have had a big oven cause our lights are HUGE!
I have a extra set of lights that im tempted to try it on. I'll probaly try it in a couple of weeks. Cause it just looks so clean. Sorkang... did you run into any problems? Did you actually bake them in an oven or go with a blow dryer like Mike? Also, did you seal it up with anything or did you use the exisiting adhesive?
18' volks, TRD RSB, TRD FSTB, TRD springs, HID retrofit. Micheal T's Grille ..... Silver ICE
ndoyank
Postby sorkang724 » Thu May 12, 2005 6:38 pm
yes guys, it sounds like alot of work, but is not. make sure you do it with a buddy tho, i actually bake it in the oven, the buddy who helped me have numerous experience with baking headlights, so i was not worry. the headlight actually did not fit in the oven, we had to bake it with the oven open , we just check it every few minutes to see if the silicone melted.
sorkang724
Postby michaels artic frost » Fri May 13, 2005 12:12 am
Nice work Jackie! Props bro! :wink: Hella nice and clean.
Updated 06/01/12: Michael T's
Postby SpeedSTARs » Fri May 13, 2005 12:26 am
Da..yam looking pretty stealth :wink: ... Good job, keep up the good work. :P
SpeedSTARs
