SolaraGuy.com • View topic - Great upgrade tires
Great upgrade tires
Great upgrade tires
Postby the penske file » Fri May 13, 2005 11:10 am
I just upgraded my tires from the OEM Turanza to the Toyo Proxes TPT. Like driving a different car - incredible handling tire. If your looking for new tires don't overlook these.
the penske file
Postby slingshot » Fri May 13, 2005 3:22 pm
What size did you get and how much were they?
slingshot
Postby PhreakdOut » Sat May 14, 2005 11:22 am
Has anyone changed tire sizes but kept the same OE wheels?
For example: Go from 215/55/17 to 235/50/17
The circumference is close, but I'm curious if it's any wider or is it clears OK.
TOYO upgrade
Postby the penske file » Mon May 16, 2005 8:03 am
I stuck with the standard tire size 215's per advice from Tirerack and my local car expert. i know the fatter tires may look a little cooler..... but these Toyos are amazing in the OEM size.....changed the dynamics of the car.
the penske file
