SolaraGuy.com • View topic - Finally got my K&N drop in wow!
Postby CHRIS CLUTCH » Sun Jul 03, 2005 11:19 am
So the lag TSB didn't show up so I went with the K&N drop in to see if it would help. Man what a difference. I barely hit the gas yesterday and I peeled out. The lag is completely gone especially off the line and in high speeds when I need to merge or pass. A big hellz yeah! to K&N. One question though the Sales Manager at Toyota said to stay away from the cold- air intake set-up and go with the drop in. Why?
CHRIS CLUTCH
Postby Astro » Sun Jul 03, 2005 11:23 am
I think it's because dealers hate aftermarket parts.
Postby CHRIS CLUTCH » Sun Jul 03, 2005 12:24 pm
--1LOKEDOUTSLE-- wrote:There is no cold air set up (its a Short ram) and I have a K&N drop in right here.....
Ok yeah then the short-ram, what are the ups/downs of it?
CHRIS CLUTCH
Postby StockSolara » Sun Jul 03, 2005 12:49 pm
Short Ram for a street driven car will suck in too much hot air from the engine from off the line in which will make you loose more torque and hp. . . On the highway it should be better since more air is entering the engine. . . That is why the cold air is better because the filter is on the outside sucking in cold air instead of the engine compartment air
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby CHRIS CLUTCH » Sun Jul 03, 2005 1:01 pm
Got it. Thanks man I'll just stick with my drop-in for now, but the cold-air sounds good.
CHRIS CLUTCH
Re: Finally got my K&N drop in wow!
Postby slingshot » Sun Jul 03, 2005 4:54 pm
CHRIS CLUTCH wrote:So the lag TSB didn't show up so I went with the K&N drop in to see if it would help. Man what a difference. I barely hit the gas yesterday and I peeled out. The lag is completely gone especially off the line and in high speeds when I need to merge or pass. A big hellz yeah! to K&N. One question though the Sales Manager at Toyota said to stay away from the cold- air intake set-up and go with the drop in. Why?
Wow, I want what you're taking. :D Well, whatever you gotta do to get rid of the lag. Hmmm, I saw almost no change from the K&N filter but a big change from the TSB lag fix. The TSB doesn't show up, you just tell the dealer you've experienced the things the TSB says it fixes and you ask that they apply it. I guess you don't need it now though.
slingshot
Postby SPF 0 » Sun Jul 03, 2005 6:36 pm
Astro wrote:I think it's because dealers hate aftermarket parts.
FWIW, I thought that having an open intake like that increases the chance (albeit still remote) of water being introduced into the engine.
SPF 0
Postby RichD978 » Sun Jul 03, 2005 6:39 pm
i din't know a drop in would make such a difference?
RichD978
Postby dvdchris45 » Sun Jul 03, 2005 7:01 pm
RichD978 wrote:i din't know a drop in would make such a difference?
Ditto. Its just an air filter, I'm waitin to get the Injen intake and quite possibly a custom dual exhaust setup. (My cousin bought a rear-ended red Gen 2 and is in talks with a welder friend of ours...keep your fingers crossed..
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby bassthrive » Sun Jul 03, 2005 8:37 pm
If the cold air intake hangs low enough and you drive through water deep enough to completely submerge the filter then yeah, thats correct. All in all, any intake, short ram or cai, isnt going to give you the numbers the companies over-estimate to begin with. (However, IMO it is worth it if you are boosted.) Stick with the drop-in... the last air filter you'll buy.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Astro » Sun Jul 03, 2005 11:23 pm
Check out my CAI. I've never had any problems, even going over puddles. You only have to worry if the filter gets submerged in water. If you think about it, you would pretty much have to drive into a lake for anything to happen.
Postby Down2TheC » Tue Jul 05, 2005 2:52 pm
The drop in should add about the same as the Injen. i measured my OEM airbox ports and after 3000rpm (or before w/ the DocJohn trick) you have the equivalent of a 3" pipe. So the filter is the only improvement. Actually, OEM has a little more area w/ the two ports open. Concentrate on the headers if you want real power. That's our choke point. (exh might help some tho)
Down2TheC
Postby SPF 0 » Tue Jul 05, 2005 3:42 pm
Will the fuel injection computer change the mixture if you really started to flow a lot more air? Or would it just lean it out even further?
SPF 0
Postby JayDubz » Thu Jul 07, 2005 12:17 pm
NO true.. LOL i had a cold air intake where my fog lights are.. you cant see in my sig pic cuzz they are old pics.. but you could see my firlter behind my fog light and on a rainy day in san diego on the free way my car chugged on the free way and turned off my intake sucked water all the way pass the sensor... it fried my sensor but my manifol was coo.... when you get cai that are down low make sure it is covered well.. or you will have major problems... get shields all around :drinking:
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
