SolaraGuy.com • View topic - i found a down side for the injen intake
Postby TRDMIKE3 » Thu Aug 04, 2005 3:01 pm
I've notice that to open,close or crack up the sunroof i have to hold the buttons. Before i didn't have too.. you guys should check that out,
it might have something to do with the vacuum lines on the intake.
what's going on here?
ohh by the way the car sounds like a Z,,, so cool.....
but what's up with the defects
Hey man thanks for that pic of the intake, from what i see the ports
looked solid or sealed at the tip ...
TRDMIKE3
Postby Astro » Thu Aug 04, 2005 3:07 pm
I've had the intake for years and never had that problem.
Postby so-cal_sol » Thu Aug 04, 2005 3:11 pm
um.... what does your intake have to do with your sunroof??? and also did you disconnect your battery? if you did then the switch for the sun roof has reset. it needs some time to relearn the auto function. so drive it around a little and after a while it should work again.
2005 lunar mist metallic se V6
Trenz Grill
Eclipse 2454 HU
TRD springs *DROPT BY MILT*
so-cal_sol
Postby cklinh » Thu Aug 04, 2005 3:18 pm
just driving around isn't going to work... you need to "retrain" the moonroof...
just open it all the way, then close it all the way, and it should work again.
cklinh
Postby TRDMIKE3 » Thu Aug 04, 2005 6:28 pm
yes i did disconnect the battery, but i'll take your advice and try that.
TRDMIKE3
Postby Turbosolara » Thu Aug 04, 2005 7:44 pm
intake has nothing to do with your sunroof. if your car still under warranty, then just send it back.
Postby theprodigy79 » Thu Aug 04, 2005 10:09 pm
Cklinh is correct... except you will need to COMPLETELY open and close it three full times... if it stops before it is completely open / closed, release and repress until it is completely closed or opened.
theprodigy79
thanks problem fixed
Postby TRDMIKE3 » Fri Aug 05, 2005 6:15 pm
i had to play around with the sunroof, it works now,
my bad
TRDMIKE3
