SolaraGuy.com • View topic - Anybody tried this stuff?
Postby 04SolaraGirlie » Mon Aug 08, 2005 10:17 am
Has anybody tried that new Q high performance "heat activated" motor oil? I put mobil 1 syntec in mine and notice a very small increase in fuel economy but no noticable increase in performance... Is it bad to switch ooil brands, my bf said if your car didn't come with synthetic that you're not supposed to switch it out, or something... Anyway was just wondering if any of you have tried that quakerstate Q...
http://www.qpower.com/
2004 Toyota Solara SE, 4 banger 5 speed. Bought on 3-24-2005.
04SolaraGirlie
Postby 04SolaraGirlie » Tue Aug 09, 2005 9:08 am
nobody?
04SolaraGirlie
Postby cRaCkeD oUt » Tue Aug 09, 2005 3:38 pm
You will never notice a difference in performance by changing motor oil.
Changing motor oil frome either regular to synthetic will not harm your engine. Just save your money and use regular Castrol 5-30 oil.
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby 2AZ-FE » Sun Aug 14, 2005 11:09 am
I haven't used the new "Q" but if anyone should know, these guys are pretty knowledgeable about oil (click below):
http://www.bobistheoilguy.com
Try a search of their oil forums. Their Air Filtration Test is interesting, too.
As competitive as the Engine Oil field is, I can't see this new Q being significantly or noticeably better than the Mobil 1 you're using now.
It's fine to switch to or mix synthetic as long as you don't mix the oil weights/grades (e.g. don't top off 5W-30 with 10W-30, etc.). I have heard that synthetic might cause seal problems in old cars (I don't use synthetic in my really old car, so I can't confirm). None of our Solaras are THAT old.
It's also generally advised to try to stick to one brand of oil, since different companies use different additive packages in their oil (The additives are usually what they're bragging about in their ads.).
2006 Solara SE
2.4L Four, 5-speed Auto
2AZ-FE
Postby Mandarinsolara » Sun Aug 14, 2005 11:19 am
royal purple
Mandarinsolara
Postby StockSolara » Sun Aug 14, 2005 1:34 pm
2AZ-FE wrote:I haven't used the new "Q" but if anyone should know, these guys are pretty knowledgeable about oil (click below):
I just read those tests he did with the different companies and materials that air filters use. . . I'm surprise at the results
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
