SolaraGuy.com • View topic - Weapon-R Intake
Weapon-R Intake
Weapon-R Intake
Postby cRaCkeD oUt » Tue Aug 09, 2005 3:31 pm
What do you guys think about the Weapon-R Intake for the Solara i4?
Its 100 bux cheaper than the Injen... even tho it looks like crap, how much performance difference would it really be less than the Injen? And if it is significantly less, would it be noticeable?
And what is the difference between the i4 MAF and v6 MAF? Could the i4 use the v6 MAF?
http://www.prolightstar.com/wr_dragon/w ... 05144.html
______________________________________________________
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby vaseline » Thu Aug 11, 2005 5:04 pm
I am curious about this also.
2005 Solara SE Sport
vaseline
Postby DatSRBoi » Thu Aug 11, 2005 6:15 pm
Injen did their R&D more... Weapon R just sort of threw stuff together and called it a day... Its been known to cause Checklight when I checked one out..
Postby ~Spadwaller~ » Thu Aug 11, 2005 6:21 pm
Weapon R has no CARB sticker either
~Spadwaller~
Postby RichD978 » Thu Aug 11, 2005 6:23 pm
not 100 cheaper than injen... i got mines for 160 shipped... jux gotta wait for an oppurtunity bro
RichD978
Postby kgzero1 » Thu Aug 11, 2005 6:44 pm
LOL! ~Spadwaller~, that avatar is hilarious! And scary!
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby PhreakdOut » Thu Aug 11, 2005 9:56 pm
kgzero1 wrote:LOL! ~Spadwaller~, that avatar is hilarious! And scary!
Yeah! I really need to turn off the avatars while I'm at work. That would scare my coworkers.
Postby ~Spadwaller~ » Fri Aug 12, 2005 1:47 am
:lol:
~Spadwaller~
I got one
Postby IndySolara » Sat Aug 20, 2005 6:08 pm
I put one in about a week ago and it makes the car sound very deep around 3k and all the way up. It makes highway passing much easyer. I will post a pic later.
IndySolara
Postby Down2TheC » Sun Aug 21, 2005 8:18 am
Unless they screwed up the Vac tub routing or changed the pipe size, it should have the same performance. The pretty outside of a pipe doesn't do a lot for the engine. Bends have minimal impact too. As long as there is no heat issue with the materials requiring a heat shield.
Down2TheC
Postby DatSRBoi » Sun Aug 21, 2005 9:20 am
down2thec wrote:Unless they screwed up the Vac tub routing or changed the pipe size, it should have the same performance. The pretty outside of a pipe doesn't do a lot for the engine. Bends have minimal impact too. As long as there is no heat issue with the materials requiring a heat shield.
Somewhat true, Pipe size does matter, Bends somewhat does too so it wouldnt throw the MAf Sensor off. If you dont believe me, Throw in that gay straight pipe ebay made..It caused a CEL light everytime
