SolaraGuy.com • View topic - Scion tC Headers on Gen2 I-4 (Do they work?)
Postby PhreakdOut » Wed Aug 17, 2005 1:02 pm
Has anyone tried to install the Scion tC Headers onto a Gen2 Solara I4? Everything I've seen looks like it will work.
Check out this tutorial for installing the DC Sports SHC4402 Header onto a tC. The tutorial looks good. I question the impact of the CEL fix. (But I'm not familiar with the anti-foul product)
http://www.scionlife.com/forums/viewtopic.php?t=56520
Postby krawzyazn » Wed Aug 17, 2005 1:10 pm
no they fit on top but not where you connect the exhaust
call JPP and ask them if they can modify one of the gen 1.5 headers to your car
Postby cRaCkeD oUt » Wed Aug 17, 2005 7:16 pm
If the lower portion of the header doesn't connect to the exhaust, why don't you cut off part of the forward exhaust tubing. Then weld a cut and bend a new pipe to make it fit. I used to work at an auto shop where the guy welds custom exhausts togehter and has a mandrel bender. You'd be surprised at how they could make something work, and how affordable it would be. Are you in Southern California?
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby krawzyazn » Wed Aug 17, 2005 7:22 pm
cRaCkeD oUt wrote:If the lower portion of the header doesn't connect to the exhaust, why don't you cut off part of the forward exhaust tubing. Then weld a cut and bend a new pipe to make it fit. I used to work at an auto shop where the guy welds custom exhausts togehter and has a mandrel bender. You'd be surprised at how they could make something work, and how affordable it would be. Are you in Southern California?
can you weld to ceramic?
Postby PhreakdOut » Wed Aug 17, 2005 10:29 pm
Headers are not ceramic. They're ceramic coated. This can be wirebrushed off for welding.
Postby mmcdonald » Fri Aug 19, 2005 4:29 am
No, he's talking about cutting off the exhaust pipe and re-welding it to fit, not cutting off the header and re-welding that. Too much work. Cutting the exhaust pipe, bending a new piece and welding it inline with the old exhaust pipe to line up with the header is a snap for most shops.
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
