SolaraGuy.com • View topic - Brushed Stainless Steel Door Sills and Dead Pedal Cover
Postby Pilyo » Mon Aug 22, 2005 8:00 am
I have completed my brushed stainless steel door sills and dead pedal cover.
The door sills, I mounted an alumininum TRD emblem, purchased directly from TRD Japan at $20.00 each. The door sills are sweet and has a very sophisticated touch and the look of authenticity. The dead pedal cover a patterned off a template I made from the existing dead pedal. The dead pedal is a mount on application, choice of using screws on each corner or adhering directly to the stock pedal via RTV SilicOn. Lots of it to ensure adhesion.
The door sills, is a replacement, mounted via red/automotive grade 3M adhesive/mounting tape and a bead of RTV Silicon along the edges to make it waterproof. The results are aesthetically sound and pleasing. A definite eye candy in a subtle way. I will post pictures as soon as I get a USB cable from my cam to pc.
Below are the cost:
Brushed SS Door Sills (pair)
TRD aluminum Emblem (pair) $40.00 (optional)
Brushed SS Door sills (pair) $45.00
3M Mounting Tape Automotive Grade $6.00/roll (I used 2 rolls)
For $40.00, I would be more than happy to provide you with blank brushed SS Door Sills. You can apply your own graphics suited to your personality. And purchase the red 3M tape and if you want an artisans level of work, finish it off with RTV Silicon sealer. We will just figure out and add shipping and handling.
For the Brushed SS Dead pedal cover, I made it with "penny sized holes along the center, a total of six, 3 per side, total cost for the pedal is $30..00. You can use remaining RTV Silicon to mount it or use the screws which I will provide. Again shipping and handling will be added to final cost.
Check out my cardomain site for pictures.
1999 Blacksand SLE V6
"Shake the Disease"
http://www.cardomain.com/ride/2062730/1
Pilyo
Postby theprodigy79 » Mon Aug 22, 2005 8:51 am
Hey bro, you posted under Gen2... Do you know if these are available for Gen2 as well? Looks good (I esp like the dead pedal cover)
-James
theprodigy79
Postby Pilyo » Mon Aug 22, 2005 2:12 pm
theprodigy79 wrote:Hey bro, you posted under Gen2... Do you know if these are available for Gen2 as well? Looks good (I esp like the dead pedal cover)
-James
I actually am offering it for the Gen. 2 as well. The prices are as follows:
with TRD logo $95.00
without TRD logo $45.00
Brushed Stainless Steel Dead Pedal Cover $35.00
shipping and handling will be added to the final invoice depending on location.Option between UPS or USPS. Payment accepted: Check, Money Order and Paypal.
Thank you for your inquiry.
"Shake the Disease"
Pilyo
