SolaraGuy.com • View topic - just got 20's and have a question
Postby scis30 » Sun Sep 04, 2005 1:37 pm
I just put some 20's on my gen 2. tire size is 225/35/20 and sometimes when im driving the steering wheel vibrates but then once i hit around 50 or 60 mph it stops. i realize that my ride quality isnt gonna be what it was with the 17's cause im riding on tires with as much rubber as a condom, but would the 20's throw my alignment off? or anyone have an idea of what it is?
scis30
Postby theprodigy79 » Sun Sep 04, 2005 1:45 pm
Your vibrations would be caused by wheel / tire balance issues; I'd make sure they spun balanced them properly (most places that do tire installs offer free balance and rotation for the life of the tires). Allignment could potentially cause vibrations as well (by wearing the tire oddly); however if you just had them installed that wouldn't be an issue, and having new wheels / tires put on would not effect your allignment (so your allignment should be fine unless it wasn't right before the installation). 20"s will definitely have a harsher (and generally louder) ride than factory 17"s, however they should not vibrate or cause allignment issues. One other thing to keep in mind is that tires are not flawless from the factory... and some tires will vibrate for a bit (or have excessive road noise) untill they begin to wear evenly.
-James
theprodigy79
Postby scis30 » Sun Sep 04, 2005 2:05 pm
ok awsome thanks for info ill just give them a week or so and see if the vibrations wear down. I see your from burke. I live in MD and i have a few friends in burke. I was sposed to go to George Mason Univ. till i got sent to afghanistan.
scis30
Postby P Funky » Sun Sep 04, 2005 2:10 pm
Hey- where you from in Maryland?
Welcome to the forum!
<b>Master 'Yota</b>. K&N air filter, Sylvania Silverstar head/fog lamps Alpine CDA-9847, Blaupunkt ODc650, Alpine Type-R SPR-69LP. Alpine SWS-1022D 10". Alpine MRV-F340 55W x 4. Kenwood KAC 7201
P Funky
Postby indiglosolara » Sun Sep 04, 2005 3:34 pm
From what your saying it sounds like they didn't isntall a hub centric ring. Most aftermartket rims have a wider center bore which needs the hub centric rings to hold the wheel in place and to be centered. If you dont have these you will get vibrations at varies speeds.
If that doesn't solve the problem then i would get the wheels rebalanced...
indiglosolara
Solara 2 xB
Solara 2 xB
HubCentric
Postby JMSinMaryland » Sun Sep 04, 2005 4:17 pm
I might have an extra set laying around. Let me know if thats what's missing. Baltimore, MD myself. Jon.
JMSinMaryland
Postby scis30 » Sun Sep 04, 2005 7:45 pm
i bought the rims from the internet they came with everything, mounted balanced new lugs, valve stems.....so i think id need those hub centric things..i dont even know what they are, what do they do and how do u install?
scis30
Postby 04SolaraGirlie » Tue Sep 06, 2005 2:01 am
LET'S SEE SOME PICS! WHAT KIND OF 20'S ARE THEY?
2004 Toyota Solara SE, 4 banger 5 speed. Bought on 3-24-2005.
04SolaraGirlie
Postby scis30 » Tue Sep 06, 2005 8:47 am
check out pics at my cardomain.com page, the link is in my signature
SOLARAGUY PART 2
i'm baaack
scis30
Postby SC V6 » Tue Sep 06, 2005 9:43 am
Massive
SC V6
Postby scis30 » Tue Sep 06, 2005 1:58 pm
just put my hub centric rings on today, got them from a local tire shop for $30 installed and the ride is alot smoother that exactly what the problem was.... thanks for your help everyone.
SOLARAGUY PART 2
i'm baaack
scis30
Postby Blazed04 » Thu Sep 15, 2005 6:28 pm
Hey ive got the same Micron pipe on my bike. Minus the highmount.
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
